Common repairs on 7th gen
Old Jan 9, 2009
rcelefano's Avatar
rcelefano is an unknown quantity at this point
I've tried to search for a thread like this, but didn't find anything.
I'm just wondering what are common repairs on the 7th gen? (Things that broke a little too early).
So far, all I know is
1. Shocks
2. Compliance bushing (thx gearbox lol)
I'm trying to get my car to perform like brand new.
Old Jan 9, 2009
ronaldo9's Avatar
Re: Common repairs on 7th gen
Tie rod ends? I had to replace those when I did my shocks. My altnernator belt snapped, and I also needed new bearings for the top mounts on the struts.
Old Jan 9, 2009
DeX's Avatar
DeX
Canadian, Eh!
DeX is a name known to allDeX is a name known to allDeX is a name known to allDeX is a name known to allDeX is a name known to allDeX is a name known to allDeX is a name known to allDeX is a name known to allDeX is a name known to all
The alternator is not capable of handling much more than stock electronics and the trunk release has broken on every 7th generation Civic I've ever seen.
Old Jan 9, 2009
engine mounts too...depends on the car i guess. dont replace stuff unless you know theyre broken. sway bar endlinks sometimes snap.
Old Jan 9, 2009
rcelefano's Avatar
My car jerks when I'm coming to a stop if I leave it in 1st. I'm guessing it's due to engine mounts (another post was talking about it.)
I ordered the energy suspension engine mount inserts and LCA bushings from dezod, hopefully this is the last of my problems for a while. I still have a that weird "exhaust" vibration when it rains. Has anyone found out what it was?
I'm planning on running the car in summer, then spray the exhaust with water to see what happens lol.
Old Jan 9, 2009
its from the water causing the pipes to expand. actually there was a service bulletin even for the stock exhaust that included a new b-pipe. its basically the pipe sits too close to the frame and can cause rattle when wet. its in there somewhere
http://www.geocities.com/pfeifferperformance/TSBs.html
Old Jan 10, 2009
yellowfin's Avatar
yellowfin is an unknown quantity at this point
none whatsoever. All i've done on my car is oil, oil filter, air filters, fluids. '02 si hatch at 80k. 40k done by me in less than 2 years.
Old Jan 10, 2009
natey57's Avatar
natey57 is an unknown quantity at this point
my reverse gear follower had a sticking detent ball, causing the reverse gear to move and hit the second gear hub assembly. this only happens when turning to the right in second gear. i see honda came out with a tsb on this not to long ago.
Old Jan 11, 2009
ADMCivic's Avatar
ADMCivic is an unknown quantity at this point
The good old rocking chair driver seat seems to be another common problem.
Old Jan 11, 2009
Protan988's Avatar
Protan988 is an unknown quantity at this point
Transmisions??? About to replace mine next week. YAY!
Old Jan 11, 2009
speedfoos's Avatar
Don't downshift into first coming up to a stop. That's a no-no on any car.
Old Jan 11, 2009
mugenman's Avatar
"mmmBAHHHH" - vtec y0
never had it happen to me but the cable snaps for the fuel door. i hear thats a pretty common problem.
Old Jan 11, 2009
ive also seen alot of problems with the power windows (switch, glass, rails, everything) and locks.
Old Jan 12, 2009
gowen's Avatar
gowen should not be trustedgowen should not be trusted
Happened to me. But the dealer fixed it for free I think there was some kind of recall. Alrternator and front motor mount also
Old Jan 13, 2009
Protan988's Avatar
Yup my window fell right off the track in the summer. Had to tape the window shut.
Old Jan 13, 2009
THECHRIS's Avatar
THECHRIS is an unknown quantity at this point
my altinator. ac belt?, front and rear shocks, and the switch on my door to lock and unlock the doors.
and i think mytransmission is going.
martinsmartin
Aug 15, 2015 07:34 PM
AirJordan613
General 7th Gen
Aug 2, 2015 08:55 PM
srtlat
Jul 17, 2015 11:53 PM
