S2K Transmission Fluid
Old Dec 27, 2008
matt35foley's Avatar
matt35foley will become famous soon enough
I changed my transmission fluid this weekend (Thanks to the DIY). I put in the OEM MTF fluid that the dealerships use in the S2000's and it made a HUGE difference in my car. My shifts are a lot smoother and I have less shift shock, even when racing. If any of you wanna stick to OEM fluid use the S2000 fluid next change.
Old Dec 27, 2008
supafil25's Avatar
supafil25 will become famous soon enough
Re: S2K Transmission Fluid
is there any diff in fluid from oem to s2k
Old Dec 28, 2008
DDragon7's Avatar
I think its all the same.
Old Dec 29, 2008
It gives better proection supposedly. When I poured it in it was almost perfectly clear like water.
Old Dec 29, 2008
Protan988's Avatar
Protan988 is an unknown quantity at this point
Honda MTF is the same way. Clear like water. I think its the same fluid.
Old Dec 29, 2008
Maybe. I work at a dealership and the guy back in parts said its the Advanced Protection formula they only use in s2000's, the container itself was different from the regular OEM MTF fluid.
Old Dec 29, 2008
DDragon7's Avatar
How does the s2k MTF bottle look like?
Old Dec 29, 2008
its believeable, the s2k generally uses higher performing fluids and parts due to the big rev limit
Old Dec 30, 2008
The label is green and it says Advanced Protection in white
OptimisticWay
46
Oct 15, 2015 02:16 PM
AirJordan613
General 7th Gen
Aug 2, 2015 08:55 PM
Q-Bert
Jul 19, 2015 09:09 PM
srtlat
Jul 17, 2015 11:53 PM
Jul 12, 2015 11:54 AM
