how can i get more power
Old Nov 23, 2008
em2allday's Avatar
em2allday is an unknown quantity at this point
i want more power without a turbo kit and no nos i have intake,header,full exhaust what u have in mine to make more power i want my v-tech to pop harder how can i do that???????
Old Nov 23, 2008
BJanzen's Avatar
BJanzen is a glorious beacon of lightBJanzen is a glorious beacon of lightBJanzen is a glorious beacon of lightBJanzen is a glorious beacon of lightBJanzen is a glorious beacon of lightBJanzen is a glorious beacon of light
Re: how can i get more power
Read all the replys in this:
https://www.civicforums.com/forums/4...-na-build.html
Also learn to search.
Old Nov 23, 2008
TRIZ's Avatar
What do you mean pop? ...its vtec btw.
Old Nov 23, 2008
em2allday's Avatar
yea it vtec i want to to hit harder
Old Nov 23, 2008
BJanzen's Avatar
He wants the "nitrous effect" i guess you could call it. To be thrown back in his seat. cough he needs a turbo cough cough
Old Nov 23, 2008
Fox04coupe's Avatar
Fox04coupe has a reputation beyond reputeFox04coupe has a reputation beyond reputeFox04coupe has a reputation beyond reputeFox04coupe has a reputation beyond reputeFox04coupe has a reputation beyond reputeFox04coupe has a reputation beyond reputeFox04coupe has a reputation beyond reputeFox04coupe has a reputation beyond reputeFox04coupe has a reputation beyond reputeFox04coupe has a reputation beyond reputeFox04coupe has a reputation beyond repute
put a 4-barrel on it.
Old Nov 23, 2008
Protan988's Avatar
Protan988 is an unknown quantity at this point
You could chip it
Old Nov 23, 2008
TRIZ's Avatar
Chips dont do ****.
If you want it to hit harder, then you got the wrong car. Trade in for a civic 2000 si, or pick up an integra- aka, something with a B series motor, the vtec on motors after these cars is not the same. Currently you have vtec-E, for economy. Google it.
Old Nov 23, 2008
Fox04coupe's Avatar
i don't know how i feel about them unless you have a turbo that needs to be tuned.
Old Nov 24, 2008
ukdm_em2's Avatar
ukdm_em2 is an unknown quantity at this point
full exhaust system, aftermarket header, intake, fpr, maybe a remap and vernier pulley... other than that your gain will be 20bhp tops.
like triz said you got the wrong car go buy a dc5 or ep3 ctr, if you wanna be diff keep the em2 and boost it
Old Nov 24, 2008
speedfoos's Avatar
Yeah, it's definitely a Monday today.
Old Nov 24, 2008
sicma99ot's Avatar
just a man with a civic
sicma99ot is a glorious beacon of lightsicma99ot is a glorious beacon of lightsicma99ot is a glorious beacon of lightsicma99ot is a glorious beacon of lightsicma99ot is a glorious beacon of lightsicma99ot is a glorious beacon of light
haha you too huh? were thinking alike.
upgrade your head or turbo. search helps too, wont add hp but knowledge is power.
Old Nov 24, 2008
buy an rsx, or an older civic, or an s2k
Old Nov 24, 2008
em2allday's Avatar
nah i love my em2 i think i am goin to do a k20a3 testing the water
Old Nov 24, 2008
might as well pay a bit more for the a2. or get hondata for the a3.
Old Jan 15, 2009
civ_nate's Avatar
civ_nate is an unknown quantity at this point
with the search button
Old Jan 17, 2009
LemmieHill's Avatar
LemmieHill is a jewel in the roughLemmieHill is a jewel in the roughLemmieHill is a jewel in the rough
NA power is hard to achieve on such a small motor... but here u go:
High lift cams
High compression pistons
Valve job
Over sized valves
Bore motor
Stroke motor
Bigger fuel injectors
underdrive pulleys
Lightweight flywheel
Chip
Blueprint and balance block
Lightweight rods
Lightweight crank
Intake manifold
Port and polish everything possible
Larger throttle body
Higher pressure fuel regulator
Synthetic oil
Synthetic oil filter
Cam gear
Velocity stack
Bullnose your crank (some people say knife edge is better)
Dry sump your oiling system (this would be more affective than anything else on list)
Get a vtec controller
Anything similar to an apexi super AFC
Lower temp. thermostat
Performance radiator
Water wetter
Hotter spark plugs
Better coil-on-plugs
Ignition control
Im sure I can think of more if you get through all those. Honestly though with such small displacement it is way easier to take advantage of the high RPM range these cars operate at and boost it. For a lot less money you will see way more power output off of a turbo. If you are going to build a fully built turbo D17 however, it is about the same price to K20 swap. So you could have a fully built D17 with 245whp on 14psi, or a stock K20 with 200 STOCK.
Good luck
p.s. v-tec means very tall engine coolant right???
Old Jan 18, 2009
EM2 RYDER's Avatar
EM2 RYDER is an unknown quantity at this point
VTEC=Variable Valve Timing and Electronic Lift Control
Old Jan 18, 2009
TRIZ's Avatar
Water wetter
Could you explain what these do exactly??
Old Jan 18, 2009
LemmieHill's Avatar
HAHA, I was waiting on that... it was a joke.
Water wetter
-Blueprinting the block is exactly what it sounds like (like the blueprint for a house plan). Basically they go through and make sure all tolerances are to spec, line bore the mains, hone the cylinders, check the eccentricity of the mains (orbital plain of travel of the crankshaft inside the bearings), magnaflux the block etc. etc.
-Balancing the block is when they go in and make sure everything is proportional to what it is suppose to be. IE: A lot of times they have to go through and drill holes in the counterweights on the crank to take away weight to make sure the crank is balanced from end to end. They also make sure the rods from center point, and the pistons from each side of the wrist pin are balanced.
-Higher pressure regulator... more pressure more fuel. Just make sure you have the oxygen to supply the hydrocarbon. Remember cars run better around 14.7 parts oxygen to 1 particle of fuel. (Run better not necessarily make more power)
-Dry sumping is good ****! Dry sump uses a pump usually with 5 sections some have 6. 4 sections send pressurized oil to the block and one section is a vacuum reclaimer that sucks oil back out of the block. The dry sump pump receives oil from from an external source usually a tank mounted in car or trunk. Which look very neat by the way. Ok, the advantage to all of this is that now there is NO oil for the crankshaft to have to spin through. When the crank does not have to drill its way through thick oil (which would normally be inside the oil pan) it spins much more freely and unrestricted. This frees up incredible amounts of power. It also creates a vacuum inside the crankcase. When the crankshaft spins inside of this vacuum it spins much more freely, resulting in not only faster revs but more power because of how much easier the crank can spin. So dry sumping adds power by removing the oil in the oil pan so the crank doesnt have to drill through it, and by also creating a vacuum inside the crankcase. I built a nextel cup motor at school that gained 47 hp on the engine dyno after the dry sump was installed. So you could aim for a good 20-30 hp on your D17. FYI: all stock car motors (nascar) use a dry sump system.
-Lower temp T-stat will open up earlier keeping the coolant cooler causing the ECT to send a message to the PCM saying throw more fuel at it.
-Water wetter will just keep you engine running cooler, resulting in similar effect as above^ but on a much smaller scale.
Ok, now that all this has been said about throwing fuel at the motor let me finish by saying LEANER IS MEANER (more AIR than FUEL.) The leaner you can run your motor the more power it will make due to increased heat. If you increase heat, you increase pressure. If you increase pressure you increase power. If you go too lean, however, your motor WILL blow. Now you must keep in mind that this is all relative to what you do. Example: stock D17, you lean it out a little (lets say 15:1) and gain a few ponies, BUT lets say you get bigger injectors and a camshaft that had high intake lift values and set your fuel curve back down around 14.7:1. You will now make more power than previously (15:1) because you are allowing more fuel and air into the cylinder. But if you were to lean out your new setup (the new setup being injectors and cam) you would make even more power. Like I said, leaner is meaner but you must realize its all relative to the other factors that you change.
Keep it simple and boost. Leave the natural power for the V8's. (I hate V8's by the way)
Old Jan 20, 2009
d17civickid's Avatar
d17civickid is a glorious beacon of lightd17civickid is a glorious beacon of lightd17civickid is a glorious beacon of lightd17civickid is a glorious beacon of lightd17civickid is a glorious beacon of lightd17civickid is a glorious beacon of light
^^^ very interesting... I definately learned something new today... LOL
Old Jan 24, 2009
LemmieHill's Avatar
You can thank those german geniuses of WWII when they designed planes that could roll all the way over. Prior to then, when a plane would pitch to far one way or the other, the oil would drain out of the crank case causing catastrophic failure!! With the dry sump, no matter what the angle of the engine, it is receiving oil.
Old Feb 5, 2009
civ_nate's Avatar
High lift cams
Valve job
Over sized valves
Bore motor
Stroke motor
underdrive pulleys
Chip
Lightweight rods
Lightweight crank
Intake manifold
Synthetic oil
Cam gear
Velocity stack
Water wetter
Hotter spark plugs
Ignition control
Good luck
as far as i know these cars, due to obd-1 cannot be chipped, alone engine manigment systems, emanage or aem maybe. and the sythetic oil/filter will not generate any power. Aswell it should be mentioned that most of the mods above will not do much without the other ones.... simly doin one or two of the above mentioned items will do close to nothing, and not worth the money compared to FI.
Old Feb 7, 2009
LemmieHill's Avatar
Its funny you should mention that. All cars after 1996 are OBDII. As for a chip
http://www.racepages.com/products/?D...94965335&Nty=1
and im sure that there are more.
Synthetic oil definitely increases horsepower. Due some research. Less friction, more output. The filter, no it doesnt add horsepower but why not run one anyway if you are going through all that trouble anyway.
The quys question was not how much horsepower he could generate NA, but how. And all of those ways are ways to do so. And no they do not add much power for the price compared to boosting, which is why I stated in my first reply to leave natural power to the V8's and simply boost. You should learn more about what you're talking about before posting.
jordan1794
General 8th & 9th Gen
May 11, 2019 08:59 PM
kmarcet
Sep 26, 2015 10:25 PM
Dave1984
Jul 22, 2015 06:10 PM
breanna_17
Jul 21, 2015 04:01 PM
