01-03 Dual Halo Projector Headlights
Old Oct 21, 2008
mmaranao's Avatar
mmaranao is an unknown quantity at this point
Hi, i just installed my dual halo projector headlights and i need to align it. Can this be done easily? Any help is appreciated.
Old Oct 22, 2008
mfusco78's Avatar
mfusco78 is an unknown quantity at this point
Re: 01-03 Dual Halo Projector Headlights
your best bet is to take it to a dealership.. i work at a dealership and we have a special unit called the sniper which u place in front of the car and helps you align the headlights. most of out lincolns have a bubble gauge on the headlight.. but if you dont have the money or the resources.. the next best thing is to pull in your garage or wait til the night.. place your headlights against a white wall.. and mess around with it til it looks good.. good luck pal
Old Oct 22, 2008
mfusco78's Avatar
lol.. doesnt have to be a white wall.. i started to zone out.. any straight wall will do..
Old Oct 22, 2008
park 25 ft away from a straight wall on level ground where you can clearly see the headlight beam. measure the height from ground to center of the projector. go to the wall and measure this same distance and make a mark. turn the lights on and aim the cutoff (line between light and dark) 2 inches below the mark you made on the wall. do it for both sides. the projector housings have a bolt in the back you gotta turn and see whether it moves up or down. its prolly required that you remove the headlamp to adjust the bolt, so be ready to take them on and off a few times at least. i dont think any dealership would touch those lights.
wingsfan19
Oct 1, 2015 03:45 AM
AyyeeGeorgee
Sep 14, 2015 12:54 PM
Ultra Havoc
Sep 9, 2015 10:58 PM
Bricoleur
Sep 9, 2015 12:23 PM
MamaBear2015
Sep 4, 2015 09:04 PM
