What kind of oil do you use?
Old Oct 2, 2008
Protan988's Avatar
Protan988 is an unknown quantity at this point
I use Mobil 1 synthetic. What do you guys use and why?
I used Mobil 1 basically because it has the best reputation as a synthetic oil. I use synthetic oil because although it may be almost twice the price it will last twice as long as conventional, and gives better performance and gas mileage while protecting my engine better then conventional oils. So it actually saves you money.
Old Oct 2, 2008
Tragedy's Avatar
skate or die
Re: What kind of oil do you use?
royal purple. Its purple, and works very well.
Old Oct 2, 2008
ajhdragon's Avatar
7thgens official a$$hole
Mobil 1 synthetic and all the vehicles even in the bikes.
Old Oct 2, 2008
sethro's Avatar
sethro is an unknown quantity at this point
Mobil 1 SYN
If I could buy Amsoil locally I would use it over Mobil 1.
Old Oct 6, 2008
+MM+'s Avatar
+MM+ will become famous soon enough
I was having my oil changed at Honda for the longest time. But just recently I also switched to Mobil 1 synthetic (and K&N oil filter) because of the same reasons you stated. I am also changing it myself so it comes out to about the same price. And the big bonus is that I no longer have the douchebags at Honda trying to ***** their service on me.
Old Oct 6, 2008
valvoline maxlife 5w30 and LC20 additive. cause i like my oil to last a long time, protect the engine seals, and work better than synthetic.
Old Oct 7, 2008
mr22508's Avatar
Pistol grip pump in my lap at all times
mr22508 is a jewel in the roughmr22508 is a jewel in the roughmr22508 is a jewel in the rough
I use Red Line 5w20 sythetic because, Red Line’s synthetic motor oils are designed to provide the highest protection, cleanliness and superior drain intervals with the lowest friction for your gasoline engine. They use the most stable components available and formulate thier products for wear protection and friction reduction across a wide range of engine operating conditions. Red Line's products are unique because they contain polyol ester base stocks, the only lubricants which can withstand the tremendous heat of modern jet engines. These synthetics have a natural multigrade property which allows thier chemists to avoid bulking up an oil with unnecessary additive packages
Old Oct 7, 2008
+MM+'s Avatar
Copy & Paste much?
Old Oct 7, 2008
mr22508's Avatar
yep, explains it perfectly
Old Oct 9, 2008
rygdy's Avatar
rygdy is an unknown quantity at this point
Amsoil 0w-20 signature series. They said 25k or 1 year but I change it every 6 months. Also getting 36mpg city before Amsoil with Mobil1 I was getting 31mpg. Also change tires as well!
Old Oct 9, 2008
tknaub's Avatar
tknaub is an unknown quantity at this point
royal purple 5w-30 with K&N oil filter......i change about every 5k in my 05civic
Old Oct 9, 2008
Protan988's Avatar
Ive thought about using royal purple but I just have a hard time trusting oil that purple lol.
Old Oct 9, 2008
FALKEN's Avatar
Civicforums Junkie
Mobil 1 Synthetic
Old Oct 9, 2008
MidnightCivic's Avatar
valvoline maxlife 5w20...
Old Oct 9, 2008
crave7thgen's Avatar
crave7thgen will become famous soon enough
mobil 1 synthetic mix..iono why it doesnt seem like its workign for me..=(
Old Oct 9, 2008
royal purple barely lasts 2k miles, which is why most people dont use it on a street car. K&N oil filters are very good
Old Oct 13, 2008
tknaub's Avatar
Your crazy! lasts more than 2k.....
Old Oct 13, 2008
Krieger's Avatar
Krieger is an unknown quantity at this point
Mobile 1 synth on and a Pureilator (spelling?) one filter. 5w30.
I used to use Valvoline and amsoil and all that other stuff, but i like how mobile one synth makes my car run.
sure amsoil lets u go further with the oil, but i dont want crap floating in my engine for any longer than it has to.
Old Oct 15, 2008
talin92071's Avatar
talin92071 is an unknown quantity at this point
mobil 1 5w30 with lucas full syntheic oil stabilizer and mobil one filter and run 91 and get 38-42 mpg
Old Oct 15, 2008
chinaman's Avatar
chinaman is an unknown quantity at this point
BG Hi/Low true full synthetic, it's indepently tested against the other big name componies. Plus I get a deal on it becuase the shop I work at carries the BG product line. The test shows that Moble 1 is one of the lowest rated synthetic oil, because they start off with a organic base, so it's not a true full synthetic. Theres really only a few true full synthetic oils out there on the market. BG, AMS oil, Royal purple, Redline, ELF and Eneos(Nippon oil) are the only ones that I know of.
Old Oct 15, 2008
yup not many people know that about mobil1.
Old Oct 16, 2008
Protan988's Avatar
As long as you stick to the right grade of oil it doesnt matter what you use. Honda just says use a 5w20 oil in the engine. As long as you use 5w20 Mobil 1 it wont hurt a thing. If anything it will probably do the engine better.
Old Oct 16, 2008
allan 78's Avatar
allan 78 is an unknown quantity at this point
Mobil 1 Synthetic...... Good stuff at reasonable price.
RIPSAW
Nov 6, 2015 04:36 AM
lilrob1213
37
Jun 29, 2015 06:45 PM
civiic143
Jun 29, 2015 06:15 PM
Tim1959
Jun 3, 2015 08:15 PM
wawacito
Dec 14, 2001 08:52 PM
