new injectors serious problem
i just installed some rsx injectors. and after priming the fuel system the car had a really bad time starting. and the idle was horrible. then when accelerating it bogged real bad. and there is no top end.
can anyone help me out with this.
Re: new injectors serious problem
Hey man, looks like ya got my injectors
.....That is exactly what my car did on the stock computer w/ rsx injectors. Did you hook the emanage up yet? My map is set up for those injectors. You should at least be able to idle with the computer hooked up.
.....That is exactly what my car did on the stock computer w/ rsx injectors. Did you hook the emanage up yet? My map is set up for those injectors. You should at least be able to idle with the computer hooked up. Re: new injectors serious problem
well you can tune it for n/a but as it sets the emanage it setup for my turbo set up on 8 psi w/ 330cc injectors. The current map loaded does not have the correct injector correction factor for 330cc injectors because it threw a map code so I changed it to something closer to stock 290, I believe. You can change this by going settings/parameter setting/injector correction. I have no idea if it will work without a turbo though.
juror
May 26, 2015 06:35 PM
