Emissions control light came on after strong acceleration ????
Old Apr 19, 2008
batman900's Avatar
batman900 will become famous soon enough
Question Emissions control light came on after strong acceleration ????
Happend just recently I accelerated heavily to pass a truck on the hwy and bam the light came on ??? I havent noticed any dif in drive but its been about 100 miles since it happend and its still on. Should I just reset the battery to have it turn off and see if it comes back on or take it in to be fixed ?? I have heard of this happening before and the vehical is under warentee but its also my main means of transportation.
Big Ty for all help and replys fellows.
Edit: Darn just realised I didnt post this in the mech isues forum. sry sry
Old Apr 21, 2008
batman900's Avatar
Re: Emissions control light came on after strong acceleration ????
bump
Old Apr 21, 2008
maybe you should figure out what it means? thats the whole idea of having a check engine light. and how do you know its emissions, could be a whole lot of things. goto an auto store and have them read the code.
Old Apr 23, 2008
batman900's Avatar
I know because its not the check engine light its the emissions control malfunction light.
bump for any help.
Old Apr 23, 2008
DieMaster's Avatar
DieMaster is a glorious beacon of lightDieMaster is a glorious beacon of lightDieMaster is a glorious beacon of lightDieMaster is a glorious beacon of lightDieMaster is a glorious beacon of lightDieMaster is a glorious beacon of lightDieMaster is a glorious beacon of light
emmisons and engine light are one in the same. it's a little yellow engine outline.
somting else u can do is jump the BRN and BRN/YEL (pins 4 and 9 if i remimber corectly) wires in the OBD2 conector. this is just like the service check conector under the right hand dash of the EG's. your ABS, SRS, and check engine light will bink. count the blinks and u got your code. short = 1 long = 10 . oh and if it dosent blink and just stays on u got no codes
Old Apr 23, 2008
zenarc's Avatar
zenarc will become famous soon enough
Just hope its not p0497, im having this issue with my civic, same parameters for when the light comes on 4k rpms or just hard driving, its Low purge flow, i have replaced every emissions valve, canister, solenoid... via warranty at my dealership and **** still comes on.
Old Apr 26, 2008
batman900's Avatar
thanks guys good info. a friend of mine had a 03 and his light would come on and off randomly every so many miles but now has stayed off for the last 2 oil changes go figure on this darn thing.
Old Oct 18, 2011
brewcrewearl's Avatar
brewcrewearl is an unknown quantity at this point
Did you ever resolve this issue with code P0497, I've had the same problem for years?
Old Oct 28, 2011
tencc's Avatar
tencc will become famous soon enough
Howzit, While in 1st and accelerating to about 3000-3200 rpm the CEL came on and the engine bogged and hesitated. With the CEL still on I tried it again and it did the same thing, rev to about 3000-3200+ the engine boggs and hesitates, with lots of shudering. Has anyone encountered this problem? The car revs fine while at a stop and in neutral. The CEL stays on all the time. Any help is greatly appreciated.
Old Oct 28, 2011
get the code checked at most auto stores.
Old Nov 1, 2011
tencc's Avatar
Howzit got the code read my friend has a scanner and it faulted the cam position sensor. Fast fix, changed it out reset it and now its good to go.
cukaracha
May 16, 2015 02:11 PM
cruisers10
May 12, 2015 10:46 PM
cloudguy
Apr 28, 2015 05:02 AM
Civicchicky87
Idle Issues
Apr 22, 2015 07:16 PM
dooner24
Apr 14, 2015 07:51 PM
