Shaking Problem!
Old Apr 15, 2008
CivicG95's Avatar
CivicG95 is an unknown quantity at this point
Question Shaking Problem!
Another day, another problem! I don't know if this is the first time I have just noticed the problem or what. I have a 2002 civic EX coupe. I notice that in between 58 and 65 MPH I get a slight rumble and shake in the steering wheel, but only if I let of the gas. If I am accelerating I get no noise or rumble. The noise stops if I go below 58 MPH. What do you think it could be? I have new Raxle axles, and new Honda front lower control arm bushings, all four. Could it be the tie rod ends? Anyone else have this problem?
Thanks.
Old Apr 15, 2008
HLC's Avatar
HLC
HLC is an unknown quantity at this point
Re: Shaking Problem!
I have the exact same problem and for the life of me, I can't figure it out either.
Old Apr 15, 2008
mazdakiril's Avatar
mazdakiril is an unknown quantity at this point
good question i just notice that last week and was planing to go to an allinment shop soon.
Old Apr 15, 2008
sounds like bad engine mounts to me.
Old Apr 15, 2008
pheaton's Avatar
A descendant of 2k1civic.com
Manual transmission?
Old Apr 15, 2008
EM2Brande's Avatar
EM2Brande is an unknown quantity at this point
Could be the lower torque mount, the input shaft bearing..... mine was doing it to and was caused by both of these. If its a manual could be the same things
Old Apr 16, 2008
mazdakiril's Avatar
mines manual, lowered with rims
Old Apr 16, 2008
EM2Brande's Avatar
lowering should not cause shaking, but if you did not have an alignment done after lowering its an issue
Old Apr 16, 2008
CivicG95's Avatar
auto transmission! Anyone else have any ideas.
Old Apr 18, 2008
Christafurrr's Avatar
Christafurrr is an unknown quantity at this point
I had the same problem. Get an alignment
Old Apr 19, 2008
em2bartt's Avatar
em2bartt is an unknown quantity at this point
I think you should check to see if your wheels are balanced and then get an alignment. If its not that then it could be engine mounts.
Old Apr 22, 2008
+MM+'s Avatar
+MM+ will become famous soon enough
I just had the exact same problem. I started by having my wheels balanced and the vibration was still there. Get an alignment. It made a world of difference. I had to fork out another $100, but it was well worth it. And go to a reputable shop, because the guy that initially did it was a butcher. Pay the extra $ and get it done properly.
DVexile
Jul 2, 2021 05:25 PM
honda200192
Suspension
Oct 27, 2019 12:23 PM
blaketippett
May 29, 2015 08:02 AM
RickyRocket
Nov 30, 2001 10:14 AM
Hobby2K
Bolt-on Engine Performance
Nov 9, 2001 04:08 PM
