knock in engine heLp
Old Mar 28, 2008
nastasi980's Avatar
nastasi980 is an unknown quantity at this point
Got a problem guys. At start up, noticed a bad "jackhammer" sound coming from the engine block. It only does it until the engine warms up. The sound is not too loud but does concern me. It sounds like it is a piston knock. Any suggestions? Please help...Thanks!
Old Mar 28, 2008
Envy's Avatar
Diamond Member
Envy is a glorious beacon of lightEnvy is a glorious beacon of lightEnvy is a glorious beacon of lightEnvy is a glorious beacon of lightEnvy is a glorious beacon of light
Re: knock in engine heLp
thats the little hamster inside.
anyway that sounds like some serious knocking. but knocking is usually inside the head? id take that to a mechanic asap.
Old Apr 23, 2008
utahbmxer's Avatar
utahbmxer is an unknown quantity at this point
How many miles do you have on the car? Does it only knock when there is a light load on the engine? (e.g. Slight acceleration, not at idle or hard accelerations). I had a crazy knock in my engine last month that started at about 3400rpm and on, only with light loads on engine. It started to get a little worse. I knew it wasn't valves, so I took it to my mechanic and we came to the conclusion that it was probably a rod bearing. He dropped the oil pan and sure enough, a bad bearing. Luckily I caught it before it damaged the journal on the crank.
Also last year my engine was ticking before it got warm, it was actually my timing belt about to go. These are 2 things I would suggest checking into.
danace99
23
Jun 28, 2015 08:49 AM
Supramk3
May 11, 2015 07:55 PM
BootyDo
May 7, 2015 04:46 PM
zack22490
Apr 29, 2015 03:17 PM
bsmiley
Apr 27, 2015 01:27 PM
