Help: Shifter Bushing Cracked!
Old Dec 27, 2007
GaryC17's Avatar
GaryC17 is an unknown quantity at this point
I have a 2001 Honda civic Ex Sedan. I started having this free play in my shifter in the forward and backward motion when in neutral. Opened the centre console and I found a bushing broken in many pieces. The bushing goes around a cylindrical rod that is part of the shift assembly. The bushing goes into the cable for the forward and aft lever and goes around the cylindrical rod. If I recall it should be white in colour, but it has now turned brownish. I hope my description is comprehensible. It seems no one sells this bushing. I can't recall if it is part of the shift cable end. Can anyone help me out here?
Old Dec 27, 2007
speedfoos's Avatar
Re: Help: Shifter Bushing Cracked!
You have a picture? Did you check Majestic? (www.hondaautomotiveparts.com)
Which piece are we talking about here:
If needs be I'll sell you my stock shifter for $10 plus whatever it costs to ship it to you. Shouldn't be more than $20-25 total as long as you're in the states.
Old Dec 27, 2007
02BLKCIVIC's Avatar
Official Rattlesnake Hunter
its #5 clint.
there are also aftermarket ones that are aluminum you can buy.
Old Dec 30, 2007
GaryC17's Avatar
Part #5 seems to be a metal piece. The piece I refer to goes into the hole at the end of the shift cable. It should be a white plastic piece if I recall correctly. It could be part of the shift cable end.
Old Dec 30, 2007
speedfoos's Avatar
Unless you replace the whole shifter cable assembly then, you may need to have a new bushing machined for you if it's not #5.
Old Dec 30, 2007
greeen01civic4d's Avatar
if its what im thinking, ur gonna have to replace the whole shifter cable, is it the piece that the big u-clip clips onto to hold it onto the shifter?
Old Jan 10, 2008
GaryC17's Avatar
Its basically the bushing in the "eye" of the control cable end. Just DIYED a cylinderical plastic piece I cut from a pen cap. Works for now with no more noise and freeplay. I think replacing the entire cable is not justifiable.
Old Jan 10, 2008
02BLKCIVIC's Avatar
lol good
raymondxcho
Sep 29, 2015 09:00 PM
rovafa2002
Sep 28, 2015 06:57 PM
ThatGuy913
Sep 28, 2015 05:35 PM
meicalnissyen
Suspension
Sep 24, 2015 09:28 PM
Jrosa
Sep 14, 2015 08:24 PM
