kamikaze header
Old Jul 13, 2007
  #31
rick1574's Avatar
rick1574 will become famous soon enough
Re: ebay header
nice, so it eliminates the cat and you won't throw a CEL, right?
if that's the case then that's a pretty sweet deal.
Old Jul 13, 2007
  #32
whatelse_is_new's Avatar
whatelse_is_new is an unknown quantity at this point
Re: ebay header
I just bought and installed an Ebay header, it wasn't that bad for the price, I just needed something cheap because the original header was cracked.
http://cgi.ebay.com/ebaymotors/ws/eB...3213030&rd=1,1
The removal and installation went ok, except for the donut gasket which was a different size (OEM was 1 25/32 in, and aftermarket was 2 in), and the oxygen sensor.
The precat oxygen sensor wire wasn't long enough because the location is different. I had to take the pig tails off the bracket and I tied the wires back with some wire straps, but I still think the wire is to close to the header.
Does anybody know if there are some extensions wires with pigtails I can purchase, or am I going to have to take the wiring harness apart and solder in some wire to get enough clearance.
Thanks
2001 Civic LX
about 113,000 miles
Old Jul 19, 2007
  #33
greeen01civic4d's Avatar
Re: ebay header
update: kamikaze just got here!!!! ill be installing it on sunday (next day off) ill let everyone know how it goes
oh yea, does anyone have any suggestions on how best to get the bolts to the head off??? im thinking pb blaster penetrating oil b4 i try it, any other suggestions???
Old Jul 22, 2007
  #34
DsevenEm2's Avatar
This is Myspace
Re: ebay header
let us know how the install goes today..if u get it done!
Old Jul 22, 2007
  #35
Re: ebay header
just got it done, it was a bitch(partly cuz i couldnt wait for it to cool down as much as i should.... but i got er done, and no cel, 2 02 sensor holes, and washers and nuts are needed to bolt the dp to the bottom of the header.... had to run to oriely's in the middle of the install cuz i didnt know this. also, header gasket is needed too, but it flows so much better, havent driven it yet cuz im blocked in by my u-haul truck and 3 other cars, but ill be takin it to work tomorrow and ill give another update after work. sounds great btw
Old Jul 22, 2007
  #36
Re: ebay header
So you got an lx/dx header that takes out the cat, right?
with that said, did you get an O2 Simulator? Or did you just start it up and say, "Hey! No CEL! Sweet!" lol.. If that's the case, then it'll prolly come on after a while of driving. My turbo is throwing a CEL right now (P0172 - Running too rich) and when I clear it (when the CEL bugs me) it tends to come on after 150 miles of driving..
Old Jul 22, 2007
  #37
Re: ebay header
we will find out, but it has 2 o2 plugs, yes its lx/dx, hopefully it doesnt come on, ill keep everyone posted, but it shouldnt considering the 02s are pre and post cat, so if they are the same output then no problem hopefully
Old Jul 22, 2007
  #38
rick1574's Avatar
Re: ebay header
we needs pics
Old Jul 22, 2007
  #39
Re: ebay header
will post pics tomorrow, camera wasnt charged when i finished, ill post em up when i get home from work
Old Jul 22, 2007
  #40
Re: ebay header
sure, its gonna read at the same points, but since you don't have a catalytic converter anymore, your post-cat O2 sensor will read a differently, which will prolly cause a CEL to come one. I know when people with ex's (or lx/dx exhausts that convert to an ex exhaust system) put a "high flow cat" (read: megan test pipe) they put mechanical O2 simulators to pull the actual sensor part of the O2 sensor out of the actual exhaust stream to read a "leaner" a/f ratio in the exhaust stream. I personally have a random tech high flow cat and before I went turbo, I had no A/FR related CELs..
Cliff's Notes: You may throw a CEL in the next 100 miles or so because you don't have a cat to do it's job
Old Jul 22, 2007
  #41
Re: ebay header
+1 for u for good info, thanks for the heads up, i already spent like 350 between new bolts, gaskets and header, so hopefully i dont hve to spend more
Old Jul 23, 2007
  #42
Matteo's Avatar
Matteo will become famous soon enough
Re: ebay header
hey wat was ur set up before turbo
cuz i was thinking of a megan header and random tech cat and weld that to my magnaflow cat back exaust
i was also wondering that maybe that would be less loud compared to just a straight through kamikaze...anybody kno if thats true?
Old Jul 23, 2007
  #43
Re: ebay header
ill tell u the kamikaze is really loud, i have no resonator either, so its def not quiet, as far as i can tell, it sounds about like a friggin drag car
Old Jul 23, 2007
  #44
Re: ebay header
AEM v2 intake, Kamikaze ceramic coated header, random tech high flow cat (2.5" flared inlet with 2.25" piping) and finishing it off with an APEX'i WS-II exhaust. The only time I really noticed it being louder was at WOT or close to it. Then again, the WS-II is a chambered exhaust..
I'll tell you this much, when I FIRST installed the downpipe I somehow managed to mis-align the downpipe and header by about a half inch and god damn that was loud.. lol.. not to mention the car ran like crap. I realized what I did and fixed it. It was a bit louder, but not too much.
Seeing as how you've spent so much, I'm sure another 20 bucks (if that even) for a home made mechanical O2 simulator wouldn't hurt, compared to spending another $250 for a random tech high flow cat.
here's what the mechanical O2 simulator looks like. Alls it is is 2 Spark Plug non-foulers (one as is, one bored out to accommodate the O2 sensor) essentially stacked and then inserted into the O2 sensor bung that exists on the header.
Linky for O2 Simulator
Mind you, this is just in case your CEL decides to pop in and say hello.. Which it might.. There are electrical O2 simulators out there, but back when I was researching that they ran about $60 or something ridiculous like that, which is why I decided to stick with the cat. Also, I'm trying to find a way to make my car emissions legal in NV.. Good luck!
Old Jul 23, 2007
  #45
Re: ebay header
thanks for the info, if i get a cel, ill def take care of it, thx fore all the trouble uve gone through
Old Jul 23, 2007
  #46
Re: ebay header
hey, no problem man.. I was at that one point in my modding so I'm glad to help out. Plus I have nothing better to do than to troll around 7thgen and look at random threads
Old Jul 23, 2007
  #47
Matteo's Avatar
Re: ebay header
well do u guys think it would be like ricy..."i can hear it a street away" loud?
if i did a kamikaze straight to my magnaflow cat back?
or u think doing a meagan ex header and magnaflow cat/random tech. would be quieter?
btw...could i get a meagan and then get a universal magnaflow cat and direct bolt it to my magnaflow exhaust? or would i still have to get it welded to the exhaust like a random tech cat..
Old Jul 23, 2007
  #48
DsevenEm2's Avatar
This is Myspace
Re: ebay header
now im kind of confused. there is a kamikaze header for the ex right?
and Matteo i think ull have to get some parts welded. if u take out ur cat, its gona sound horrible. i had a friend do that recently. i duno..soudns really bad to me. very ricey.
u said "btw...could i get a meagan and then a universal magnfalow cat and direct bolt it to my magnaflow exhaust", i dont think i udnerstood that. megan header...to magnaflow cat...to the rest of ur exhaust. yea u can do that but since the magnaflow cat is univeral, u will have to get it welded.
Old Jul 23, 2007
  #49
Re: ebay header
well, i just got home from work, and it sounds horribly ricey, but i found out that its from when i had my resonator removed, the exhaust shop put in a straight pipe in its place, and didnt weld all the way around the pipe, they just welded the bottom, so i have a really bad exhaust leak, but i didnt find out till today since the kamikaze moves so much more air. secondly, as was already previously stated, i already have a cel, which came on after like 50 miles, if that. looks like im gonna hve to do something to resolve it.... anyway, on to the postives, minus the ricey exhaust leak sound, it increases flow really well, and the mid to high end power output is pretty good, not huge but noticeable by my *** dyno.... overall rating an 8.5 because of the small problems ive run into
Old Jul 23, 2007
  #50
Re: ebay header
tell me something, why does my exhaust sound so ricey??? is it cuz i got rid of the cat??? btw its only when i really get on it
Old Jul 23, 2007
  #51
rick1574's Avatar
Re: ebay header
post up some pics.
Old Jul 23, 2007
  #52
Re: ebay header
forgot to charge the batteries again, plus its dark already.... im such a slacker
Old Jul 23, 2007
  #53
Re: ebay header
heres some pics, found out that camera has a nighttime setting.... anyway, enjoy all u pic requesters out there
ID:	72045   Click image for larger version
ID:	72046   Click image for larger version
Old Jul 24, 2007
  #54
DsevenEm2's Avatar
This is Myspace
Re: kamikaze header
god those things are ugly lmao. yea man u removed ur resonator and put a str8 pipe of course its gona get loud.. plus no cat.. if im getting this right. throw in a universal resonator from magnaflow..theyre nice. and...i duno wat else lol..
Old Jul 24, 2007
  #55
Re: kamikaze header
im getting dnx midpipes, so resonator built in, and chrome piping for $116, so problem solved
Old Jul 25, 2007
  #56
DsevenEm2's Avatar
This is Myspace
Re: kamikaze header
what does "chrome" piping do... is there something beneficial to that. or do u mean like stainless steel..
Old Jul 25, 2007
  #57
Re: kamikaze header
Your exhaust sounds ricey because of the exhaust leak. If they fix that exhaust leak it'll help alleviate the raspy fart-can-ness.. lol.. also, putting a resonator in line wouldn't hurt either.
As for the CEL, look into the mechanical O2 simulator/fix or spend the extra money and get a random tech high flow cat. It's about $250, but it's a functional catalytic converter and will not throw a CEL. You might be able to get away with changing to an ex exhaust setup, you'd also have to extend the wires on your O2 sensors for that to work though. I don't know what else that swap would entail though..
Old Jul 25, 2007
  #58
Re: kamikaze header
started the mechanical 02 sensor simulator today, will post up pics when im done...
Old Jul 27, 2007
  #59
DsevenEm2's Avatar
This is Myspace
Re: kamikaze header
ur doing urs hand made with the non-fouler?
Old Jul 27, 2007
  #60
Re: kamikaze header
yep, sure am, ill let u know how it goes, i need to get a 1/2" drill bit
