In-cabin Noise Reduction ?
Arite Guys, I searched on the whole forum and this issue hasnt come up by anyone else. So my first question is,
1) Am i the only one who experiences so much NOISE while driving on the highway??? I have low profile tires, I understand but this noise is just too much!!! ... I drove like 300miles last week and It was surely deafening guys !!!
2) If im not the only one what do u guys recommend as a solution ?
3) Anyone else on the forum who had the same problem and found good remedy ??? Please lemme know.. Thanks all
Re: In-cabin Noise Reduction ?
1. get softer tires
2. rip out interior, cover in dynamat or similar product
3. get allignment done, may help tires wear better(im assuming ur getting a whirring noise)
theres always rust proofing.
tell the guys to spray the black stuff under you wheel wells and frame... it prevents rust AND dampens noise
i have whrring noise... but that should be eliminated by getting new tires. i think its caused my tires being feathered.
and yeah.. low pro tires are noise as ****.. but youre going for the look so you cant do anything about that.
I like my commute
i had a similar prob.. at 40 I was going deaf.. and the prob was the lack of camber kit on my lowered car. The tires weren't making proper contact w/ the road, combined w/ high performance tires = loud *** noise.. Do you have a camber kit?
Im definitely getting rid of my G2 Style Side mirrors, coz they do contribute towards the noise. Secondly, I would like to add that when I drive through standing RAIN WATER, I hear the sound of water gushing from underneath clearly from under the car.
I recall that the ****ing technician who installed my rear and front speakers 2 years ago got rid of some WHITE THERMOPOLE kinda stuff which was stuffed with in the front doors between the panels and the door. Re: In-cabin Noise Reduction ?
This is a site used for testing the products as well as some installation instructions.
http://www.sounddeadenershowdown.com/
Electric Boogaloo...
Search up sound deadening. There are hundreds of threads about it. What you're wanting to do is to deaden the interior and prevent sound from coming in. Deadening your foot wells will do a lot to help out, as they are a major culprit for letting sound in. I'd probably recommend some type of mat deadener (two layers minimum) and a layer of liquid deadener on top of that. That should eliminate a whole lot of the road noise. Seond would be the door panels. Make sure you deaden inside the frame, as well as the exo skeleton of the door. I'd use mat deadener as much as possible on the inside of the door,especially on the large flat panels. Then I'd cover the mat and entire inside of the door (especially the parts you couldn't get) with liquid deadener. The trunk would be where I finish up after I deaden the entire cabin area. If you have a system, deadening the trunk will be most likely the first step though, as the system will create sonic vibration and resonance with lots of panels in the trunk. If you don't have a system, you could save the trunk forlast.
Well there isnt much price difference in both of em ... So i guess Ill go with Dynamat Extreme for now..... One more thing Alpha, Are these things heavy ? As in, do they add a lot of weight or its just fine ???
www.sounddeadenershowdown.com all the info you'll need on all of the mat deadeners you mentioned, and written and researched by a forum member.
nirvanaguy
25
Oct 26, 2017 07:26 PM
Josh 1973
Sep 7, 2015 10:10 AM
junkyardguy
20
Sep 6, 2015 10:07 PM
tommycanada
Sep 5, 2015 04:59 PM
