hx ecu vs ex ecu
Old May 7, 2007
2slowem2's Avatar
2slowem2 should not be trusted2slowem2 should not be trusted
hx ecu vs ex ecu
Hi i swapped out my lx engine for a complete ex engine.The problem is i purchased a ecu from ebay and it was supposed to be for a 01-03 ex 5spd,well i called honda today and its from a hx 5spd 01-03.So i need to know if there are any other differences in the two besides when vtec kicks on.The guy from honda says no but he is just a parts guy please help soon thanks sam
Old May 7, 2007
ronaldo9's Avatar
Re: hx ecu vs ex ecu
Not sure but the HX might use a wideband primary 02 sensor and and 01-03 EX uses a narrowband 02 sensor. So it might not run properly. But ill confirm that for you.
Old May 7, 2007
2slowem2's Avatar
That was one of my concerns!thanks alot,one more thing is the emanage blue capable of controlling the vtec e .Or just the vafc?and if the emanage blue does not can i use the vafc with the emanage!Thanks alot
Old May 7, 2007
ronaldo9's Avatar
If you have an lx with vtec head swap yes emanage can control it with the right wiring. If you have EX ecu it gets kind of screwy and emanage is not really good at controlling it but honestly you're better off letting the ecu control it. I have not known anyone to use both VAFC and Emanage so I'd just choose one or the other. I have not heard of any issues with VAFC controlling VTEC though.
Old May 7, 2007
2slowem2's Avatar
Well see i swapped whole engines not just heads,I already purchased the emanage on here,because i am running a t25 turbo.I just dont know if i should sell this ecu and get a ex ecu or not?I have the ex wiring harness so the vtec is already wired.
Old May 7, 2007
ronaldo9's Avatar
Well I dont wanna tell you the wrong thing so I'll let other ppl with more mechanical knowledge to chime in but I'd say keep your eye out for EX ecu if its being sold pretty cheap just in case. I can't imagine why you won't be able to use the HX ecu but you're tune will be very different compared to the EX ecu. You probably will just need to swap out that primary O2 sensor.
Old May 7, 2007
ronaldo9's Avatar
I just realized what year is your engine. Straight from hondata 04-05 EX and 01-03 HX have the same compatible wideband 02 sensor. So you might be fine afterall. However if you have an 01-03 EX that uses the narrowband primary 02 sensor.
Old May 7, 2007
2slowem2's Avatar
I think i am just gonna get a ex ecu i have been shopping around since i found out mine was a hx ecu.I cant find one though except for like 600 bucks
Old May 7, 2007
ronaldo9's Avatar
wtf.. PM Sujak asap. He was selling an EX ecu for like 200 bucks probably 100 bucks actually but not sure if its sold yet. He's at work now and gets off at 10. I'll ask him when he gets online. Otherwise keep looking man. If I had money for hondata I'd sell you mine right away lol, but im not there yet.
Old May 7, 2007
ronaldo9's Avatar
Um actually here you go
https://www.civicforums.com/forums/1...ml#post4179406
You're welcome.
Old May 7, 2007
Boilermaker1's Avatar
Jap-Euro Fusion
Keep the wideband, ditch the emanage and buy a Kpro.... works with the stock wideband and has far more control over the thing than an emangle could dream of.
Old May 7, 2007
2slowem2's Avatar
I already know the emanage is not anything special but its gonna get the job done for now i dont have the money to buy a kpro setup and get tuned,i am gonna get the k-pro after awhile and i can sneek it from my girlfreind i just spent like 3000 grand turboing my car so shes not happy.I have the ex engine and the hx ecu i bought the ecu seperate from the engine on ebay!I called honda with serial numbers from my engine to make sure it was a ex!So i guess i need a ex ecu thanks everyone for the help i hit up varner88's to see if he has the ecu hopefully he does
bolt-on-bandito
Electrical
32
Jan 15, 2020 03:25 PM
ttamrekab
Sep 28, 2015 01:22 AM
Dave Brabant
Sep 27, 2015 09:43 PM
260000milesgoal
Sep 25, 2015 07:41 PM
beanhead
Sep 24, 2015 12:04 PM
