Gen-7 pre-purchase checklist?
Hi everyone
I searched and wasn't able to find one, if it's out here. If so, a link would be appreciated.
Tomorrow, I'm inspecting / taking delivery of an '05 LX Coupe (5 spd) for my little girl. Has someone on this forum made a checklist to cover the essentials before buying a 7th gen Civic? The goal is that anyone who may not be an expert, has a list of things to check that might not jump-out at you, while kicking the tires.
Basic stuff that's generic, as well as Gen-7 specific issues to watch-out for.
Generic:
Gen 7 - specific:
If forum old-timers could chime-in over time, I'd happily keep maintaining this first post to have the complete / agreed-on list, which might be a useful resource for noobs such as myself, in the future.
At first however, if you guys could give me a heads-up for any known things to check, I'd be infinitely grateful.
2005 LX Coupe 5 spd
Cheers
The checklist so far: (this is a work in progress - give it some time)
Generic
Gen-7 Tire-kicker-detectable issues
For any points in this section, they require proper inspection and / or proof that the service has been performed
Please help prioritize. We don't want EVERY possible issue to be listed or this list will become unmanageable and will scare-away anyone thinking of buying a Civic!
Generic:
- Tips from civicforums members to make anyone a smarter used-car shopper
Gen 7 - specific:
- Any gen-7 PITA items that a forum noob would never think to check for
2005 LX Coupe 5 spd
Cheers
Generic
- Enter VIN to check for outstanding recalls here (If nothing shows-up, no news is good news)
- Enter VIN to confirm original trim / equipment here
- Test EVERYTHING: power windows, mirrors, locks, climate control, sound system... if it has a button, make sure you push it.
- Check the car's parking spot for stains that could indicate fluid leaks
- Take it to a mechanic you TRUST for a pre-purchase inspection, its money well spent
- Ask for records of required service, otherwise assume the worst
- If no proof of timing belt replacement can be provided, count on replacing that
- Check / replace the often-overlooked cabin air filter. These make a big difference... no-brainer.
- For cars in the rust belt, check brake lines and also general condition of metal under the car.
- Rocking chair issue: Check both front seats to see if they're solid or if they rock back & forth
- Squeaky clutch pedal issue: If it's a 5 speed, listen for squeaks when shifting
- I've read that gen-7s can be prone to chronic / annoying interior rattles. While test driving, run at different speeds / RPMs to see if the car will run quietly for you.
- Head gasket failure is really common on 7th gen Civic. It would be handy to ask the previous owner if it failed already.
- Rear cam seals can be an issue to check / ask about for Civics in general
- Front control arm bushings may have needed replacement - based on advice from multiple civicforum members, have the entire steering system thoroughly checked.
- Gen 7 motor mounts may have needed replacement
- If you suspect the car may have been the plaything of a tuner or someone who may be attempting to hide issues, have an ODBII reader to check for recent ECU reset and / or to check for pending MIL codes. See post #7 for explanation.
Last edited by Dorval Andre; Apr 21, 2015 at 09:49 AM. Reason: ongoing work in progress
Re: Gen-7 pre-purchase checklist?
take it to a mechanic you TRUST for a pre-purchase inspection, its money well spent,
ask when the timing belt was last changed, and PROOF of it, any other service records/receipts, etc etc
In my case, I know the timing belt hasn't been done so I'm having it changed.
Actually head gasket failure is really common on 7th gen Civic. It would be handy to ask the previous owner if it failed already.
Almost always though coolant doesn't go into the oil. Compression gases push out of the cylinders and into the coolant eventually causing the coolant reservoir to overflow. If you allow this car to overheat you'll be extremely lucky if the head gasket doesn't fail.
The oil / coolant thing was just an example of basic used car checking, If it's irrelevant or stupid, it was just my thinking out loud... not an observation on the car we're looking at. (I've edited it out of the original post)
Have an OBDII reader to check for recent ECU reset and/or to check for pending MIL codes. If the ECU has been reset or battery disconnected recently the DTC's will not be in the ready state which could be hiding a pending code.
Lower front motor mount - Tear the rubber insulator apart
front lower ball joints - non serviceable, OEM's do not have retaining C-Clip
lower control arms - Torn cracked mounts, easier to just replace the LCA
Torsion Bar drop links - broken/seperated
5 Speed Manual Transmission - Input shaft bearing noise/failure. Will require transmission removal to repair.https://www.civicforums.com/forums/1...t-bearing.html
Head gasket, if the vehicle has issues with no heat at idle in the winter or persistent low coolant in the radiator but does not actually over heat it is the beginning of the end for the head gasket. More extreme conditions will see overflow of the coolant overflow tank or just outright overheat on the temp gauge. As mentioned earlier, the cooling system will be getting pressurized by combustion gases from a failing MLS head gasket, coolant is typically not entering the oil or being burnt in the engine but is being pushed out of the system and air pockets will be present. On a cold engine if you remove the rad cap it should not be pressurized.
If you live in the "rust belt" inspect the brake lines crossing the firewall to the passenger side as well as on the drivers side inner fender as they drop down under the vehicle. Where the lines clip into the holders/retainers it will eventually wear off the protective coating and allow advanced rust to form requiring complete replacement.
Inspect/replace the Cabin air filters as they often are forgotten during routine maintenance.
These are great vehicles and relatively easy to work on. If the body is straight & clean, everything else can be taken care of with routine maintenance and a little elbow grease.
I had to drive it a half hour of highway and traffic to get it to my mechanic for the full inspection. Not too bad.
Car drives great, straight, tight, no noises except a hum that made me suspect a bearing on its way out.
Indeed, 1 wheel bearing, all 4 lower control arm bushings and that's it. With the preventive timing & accessory belts, $720 for all parts & labor and the car will be 100%.
Just took delivery - Super clean, no rust, factory paint is still nice & shiny. I think my little girl should be a happy camper.
Looks good. I'd rock it. How many miles (rather, km) on the clock? I'd definitely look at fixing the headlight haze and follow it up with any sort of UV protective coat
https://www.civicforums.com/forums/1...ight-haze.html
https://www.civicforums.com/forums/3...lear-coat.html
https://www.civicforums.com/forums/1...protector.html
the following DIY has instructions on how to remove the headlights (steps 1-7)
https://www.civicforums.com/forums/1...r-removal.html
Also, if she runs into trouble down the road, feel free to post up a question on how to fix it or PM one of the mod/admin staff. We'd be more than happy to help you out and steer you in the right direction. We'll let you know right out if it's an easy DIY job or if we'd recommend taking it to a shop.
I spent an hour searching the forum yesterday for 'resurface headlight', 'refinish headlight', 'UV headlight sealant' etc.... and didn't have too much luck. Thanks - you da' man!
My search ended prematurely though. I checked the air filter and this engine bay grime just couldn't remain. Buying a car from a little old lady is great, in that this car had never been abused but it also clearly had never been loved / pampered. Checking the air filter ended-up taking me 3 hours
Look at how corroded the battery terminals were.
Gah!
After applying a little elbow grease, it's still far from done but the worst of it is out of the way.
and also thanks for the help offer. I joined this forum before even buying this car for exactly that reason. I'll always search before I post (since many forum noobs can't seem to grasp that concept) but fear not! If I get stuck, you'll be hearing from me
they sell 3M headlight repair kits at wallmart and all other car parts stores but you can just use rubbing compound and a clean rag your going to need headlight sealent otherwise it will haze after a month. 3m has a diy on youtube.
3Mâ„¢ Headlight Lens Restoration System - YouTube
Yeah I've done them in the past with just toothpaste and a lot of elbow grease but as you mention, they haze-up pretty quick after. That's the main reason I searched the forum for DIYs, looking to see if anyone CONCLUSIVELY says that there's a UV sealer that LASTS (for at least a year).
I wouldn't mind at all spending an hour or two on this process as part of annual spring cleaning. That would be totally fine by me but every month or two would get old, fast.
My buddy wants me to to his Cadillac CTS-V and I keep telling him I won't touch it until I'm confident in a sealants durability.
Oops, sorry riceboy, didn't catch that first time: it has 111K kms, or 69K miles on it. Sounds and runs like brand new. Even over big speedbumps and terrible Montreal roads / potholes, no noises at all. I was quite (pleasantly) surprised.
Once the identified maintenance issues have been sorted-out and I've detailed it to my OCD standards, it should be a great car for my daughter.
Next: Tonight, I teach her how to drive a stick. It's either going to be
or
TBD
BTW: For such an mundane thread (just buying a used, completely stock civic) it says a lot about the friendly / helpful character of civicforum members to have chimed in as much as you have.
A big thanks from me and my little girl!
Andre in Montréal
or
TBD
Andre in Montréal
Nice looking vehicle, should last may years with a little TLC.
I may suggest looking into replacing/upgrading the ground straps that are nice green and fuzzy from the rad cradle to the block and head. Also check near the battery ground for the strap from the chassis/battery. I have read issues with ground loops on these cars with faulty grounds that may cause random electrical problems.
I'll replace and firmly re-attach both - excellent preventive tip. Come to think of it, you probably just solved a mystery on my sister's Accord
Honestly, the airbox stayed put. This was just the initial mop-down.
Next time, I'll be able to call it 'detailing'.
Yep, once the garage has done all their stuff, I'll take-over for the backyard tasks
Garage stuff
DIY shopping list so far
Any other observations or preventive maintenance suggestions, I'm all ears and grateful
Thanks again
Garage stuff
- 4 lower control arm bushings (lowlife9)
- 1 wheel bearing
- Timing / serpentine belts
- my mechanic said water pump will be fine until 2nd timing belt
- oil / filter (save me the mess)
- Ground straps (Redneck CDN)
- 4 bleed screws (Reverb2005)
- Brake flush (Reverb2005)
- pads / shoes (they're all OK til at least the fall but while I'm in there....)
- power steering flush
- cabin air filter (Redneck CDN)
- Headlight UV / sealant... (WHAT BRAND LASTS?)
- Transmission fluid (Stock 99)
- New crush washers
- HONDA coolant (thanks GolNat - I would have bought the wrong stuff)
Thanks again
This is what my brake fluid looked like last summer when I changed it....(eewww again)
Might want to consider changing the transmission and coolant as well. Coolant is every 5 years, transmission every 2 years.
Adding coolant and tranny fluid / filter to the shopping list, although I think I'll tackle just the ground straps / cabin filter and and brakes on saturday.
Within 2-3 weekends, this will be one heckuva' well-maintained little car.
It's my daughter's first car.... she better not crash it after all this.
She'll be here in an hour for her first lesson driving a stick. She moved out of home this January and is so busy with school, work etc... that I did all this so far and she still hasn't even seen the car yet
editing list now - thanks again
I know this will offend the purists but I have more mechanical experience with Civics than any sane person should have and I can tell you that you don't NEED Honda brand fluids. I'm a certified automotive tech btw and also a 3-time Civic owner.
I know I'm kinda bein a dick but how do you know that Honda fluids outperform aftermarket? It's not exactly the Coca-Cola recipe. The one exception I'd make is for Honda Bond and the OEM oil filters just because they're blue and sexy.
For example I could explain why Honda Bond is necessary based on simple principles that can be demonstrated. OK rant over. Just a ticked off mechanic who needs a reason to buy on brand name. All this anecdotal stuff is great but backup is required. Please.
im not sure wether to
or
or
or just continue to
Actually,after owning 7 7th gen civics,all a/t I can explain perfectly why the only atf that should be used is Honda DW1(z1).Clean your solenoid filters after 1000 miles on Transmax.Pay attention to the shift quality using both fluids.Every one of the 3 civics I still own have over 250,000 miles on the clock.All 3 have had garbage transmax in them.All 3 went back to Honda atf.Simply because not a single one of us knows more about these transmissions than the engineers who built them.If they say do not use anything but Honda fluid,why argue?
That's EXACTLY what happened to my car. I was so confused. I've never seen a head gasket fail where there was no coolant in the oil. It was exactly as you said. Thank you for sharing your expertise.
I got a D1. 7A2 and it's overflowing in my reservoir and I'm losing coolant and it sometimes overheats how can I fix or diy the issue I have please I bought a new thermostat and water pump and timing belt and tensioner and pulley as a kit but I don't have the bread for a head gasket so how can I remedy this
