Camber plate vs camber arm
Prelude Owner
Re: Camber plate vs camber arm
The way that it goes about adjusting camber.
Both adjust camber just by different means. Plates usually also allow you adjust caster.
Rep Power: 0 Re: Camber plate vs camber arm
I'll be getting coilovers soon. Regarding the rear end I was wondering if an arm would be fine or if that was best. I'm gonna be lowering about 2 inches
Received 1,446 Likes
Rep Power: 338 Re: Camber plate vs camber arm
camber plates applies to front MacPherson suspension.
Camber arms will apply to either the rear multi-link or double wishbone suspensions (F/R). you don't want camber plates in the rear - picture your car with your legs poking out of the trunk while you try to adjust a plate on the top of the shock towers. And making it at 0.1 degree accuracy
different animals.
different animals.
swong46
08-11-2012 09:48 PM
R.O.B.
02-09-2012 09:32 AM
inajamaica
04-26-2006 11:59 AM
Grey
16
01-16-2003 09:33 PM
