8th Gen 2006 - 2011.
traction control default on 2015 si
Old 05-29-2018
RobertD's Avatar
RobertD is a jewel in the roughRobertD is a jewel in the roughRobertD is a jewel in the rough
it's annoying how much slower the car reacts when you hit the gas with TC on and it's kinda silly to have to shut it off manually every time you start the car. with it on you hit the gas and the car jumps, falls on it's face, and then accelerates. with it off the car just goes like i'd expect.
is there a way to make it so that traction control is OFF by default?
car is bone stock mint 2015 SI
RobertD is offline
Old 05-29-2018
Colin42's Avatar
Received 1,131 Likes on 945 Posts
Re: traction control default on 2015 si
look for a fuse? someone else may have a better idea
Colin42 is offline
Old 05-29-2018
RobertD's Avatar
haha.. i thought about removing the ABS relay, but i'm thinking that'll trigger a message on the warning center plus add an idiot light or two on the cluster (:
RobertD is offline
Old 05-29-2018
Colin42's Avatar
Probably, damn modern cars
Colin42 is offline
Old 05-29-2018
With lots of wheelspin?
AFAIK no, not on a stock car.
A tuner might be able to change the default but that's not something I deal with.
OTOH, it's JUST ONE BUTTON TO PUSH. First world problems, SMH
ezone is offline
Old 05-30-2018
RobertD's Avatar
haha no. with sticky summer tires and an earth shattering 200hp, traction has never been an issue. we're not clutch-dumping teenagers over here.
never hurts to ask, sometime's i'm surprised with an easy answer
i'll just push the button. lol
RobertD is offline
Old 05-30-2018
The people using power adders and custom ECMs or tuners have talked about changing the default traction control setting, but I really didn't follow the threads much.
Might search on 9thgencivic.com or similar?
ezone is offline
Old 05-30-2018
RobertD's Avatar
i'd rather not. i like this forum much better. i'll just push the button. it's cheap and simple.
i was just asking in case there was a hidden option in one of the many menus somewhere.
thank you (:
RobertD is offline
youandme
04-15-2015 12:42 AM
sleekcivic2004
02-19-2006 01:00 PM
KaZeLL
06-13-2003 05:53 PM
obtix
05-08-2003 12:04 PM
Quick Reply: traction control default on 2015 si
