ABS, VSA, brake, warning light on after replace the wheel bearings
Re: ABS, VSA, brake, warning light on after replace the wheel bearings
The collar gear that abs uses to check RPM was likely knocked off position or something similar to that.
Take back to the shop that screwed it.
MOST common problem: Wheel bearing was installed backwards.
Next most likely, sensor damaged during the work
What fault codes does it have?
It's most likely that they couldn't take the sensor off without breaking it.
I would bring it back to the shop see what they say other than that the sensor itself is cheap and can be replaced yourself easy if the shop don't want to do it for a low rate .
rogerpop
Sep 29, 2019 10:33 AM
Steve Lane
May 18, 2016 08:57 PM
eebing
Sep 12, 2015 05:35 AM
kbxer22
Apr 23, 2010 02:03 PM
