8th Gen 2006 - 2011.
Head unit and central locking
Old Sep 11, 2016
Spamantha's Avatar
Spamantha is an unknown quantity at this point
Hi all.. I need help please.
I have an 8th generation honda civic and was casually driving listening to my stereo when all of a sudden it loses power!!
I have checked all fuses and they are fine, then I notice my central locking won't work... I can manually lock the doors but not when pressing the open and lock button on the key..
Again I checked all fuses with where fine and then went to pop in onto diagnosis but then realised the port it not working!!!
Any ideas please
Old Sep 11, 2016
Spamantha's Avatar
Re: Head unit and central locking
Also forgot to mention car drives perfectly with no other problems
Old Sep 11, 2016
Check all fuses in both fuse boxes. At least one will be found blown.
Then you may need to figure out what caused fuse(s) to blow.
Old Sep 11, 2016
Spamantha's Avatar
Thanks, as stated in the previous posts I have already done this both fuse boxes
Old Sep 11, 2016
Fuse 23 in the engine compartment fuse box supplies power for the data link connector and several other things including the radio.... Is there battery power on both sides of that fuse? (using the test tabs on top of the fuse)
That circuit passes from the engine compartment fuse box, through a couple harnesses and the dash fuse box and dash junction box before reaching the radio and DLC, there could be loose harness connectors in any of the units mentioned.
Wait....Your info says you are in GB? My info is for North American cars, so this may not be accurate for your car.
You may need a wiring diagram that is for your specific car, and some testing.
ezone
May 6, 2021 07:41 AM
dennisp
Mar 26, 2016 08:51 PM
WEG
Mar 22, 2016 11:29 PM
edm82
Mar 20, 2016 03:15 PM
Theodorekaminsk
Mar 15, 2016 12:35 AM
