8th Gen 2006 - 2011.
B24 service code.
Old Aug 23, 2016
Buell13's Avatar
Buell13 is an unknown quantity at this point
B24 service code.
Hi new guy here. 2012 civic - Trying to catch up on my girlfriends Honda services. It has a b24 service code. I looked it up and looks pretty basic I'm just confused about the timing chain. My understanding is that the newer ones don't need to be replaced like the older ones. Is there anythimg i need to do with the chain, lube/tighten ect? Or us it just on there from the older Hondas?
Thank you for your help!
Old Aug 23, 2016
Buell13's Avatar
Re: B24 service code.
Sorry i just picked up the car and its B124
Old Aug 23, 2016
B124 maint items.....is explained in your owners manual.
B: Oil change, thorough inspections,
1: rotate tires, (If needed) check brakes
2: replace filter set, (if needed) and inspections
4: Spark plug set (if needed). Use exactly what the factory put in there, don't cheap out.
#4 comes up around 100k miles.
If you don't know anything about the service history, I'd strongly suggest replace the trans fluid (HONDA FLUID ONLY) and since the car is at 100,000 miles it is probably time for a coolant service (again HONDA coolant)...(maybe your sticker will say 120k, I can't remember which) '
and brake fluid flush (every 3 years)
The engine does not have a timing belt, it has a timing chain.
Normally the chain does not ever need serviced, BUT if oil maintenance is neglected the chain can suffer wear.
Old Aug 23, 2016
Buell13's Avatar
Thank you ezone!! One last question, should i check the valve clearance or im ok if it doesnt make any funny sounds? I cant do that part myself
Thanks
Old Aug 23, 2016
Thanks
If you wish.
Keep in mind:
Loose valves make noise.
Tight valves don't make noise.
Tight valves can cause a variety of problems...but worst of all, tight valves can burn.
At the shop we try to suggest it as a 100k maintenance item, but it sure seems like very few people go for it.
It seems rare to actually see issues caused by it these days, but occasionally it does happen.
Spider Saiyajin
Nov 21, 2015 03:02 AM
codbo84
Nov 15, 2015 12:54 AM
trv020
Oct 28, 2015 10:37 PM
maxtierney
Suspension DIY
Oct 27, 2015 07:12 PM
JoeNC
Dec 22, 2001 03:18 PM
