My windows and doorlock arent working
So...my power windows and the doorlock on my driver side stopped working. The doorlock on the passenger side is working fine but the power windows isnt working either. I can still use my remote to lock and unlock the car. The power control on the side mirrors are working...
What can I do to fix my power window and doorlock on the driver side and the power window on the passenger side? Thanks.
2012 Civic coupe DX
2012 Civic coupe DX
Re: My windows and doorlock arent working
Drivers door: Power lock quit......but only when using the switch on the master panel?
Drivers door-- does it lock if you push the lock switch on the passengers door?
If you stick the key in the drivers door lock and twist and hold it, does that activate power lock in passengers door?
Both doors: power windows quit?
Check fuses
A29 (engine compartment fusebox)
B5, 8, 9, 15, 30, 32, 33, 41, 42 (dash fusebox)
Does the light inside the window switch button light up?
See if the drivers power window (master) switch is unplugged. Maybe someone had the door panel off and didn't get the connector latched in all the way.
Check fuses
Check fuses
Check fuses
jqnst
Feb 26, 2016 11:19 AM
Kigoral
Feb 8, 2016 11:34 PM
