Help to choose the right rim
Hi everyone,
I am trying to get new rims for my 2006 Honda Civic LX Coupe, the size of my tires are P205/55R16 89T
I want to get these ones:
http://www.amazon.com/Maxxim-Ferris-Black-Machined-5x100mm/dp/B004Q9UAHO/ref=sr_1_1?s=automotive&ie=UTF8&qid=1399733105&sr=1-1&keywords=Maxxim+Ferris+Black+Wheel+with+Machined+Face
These are the wheel specifications:
Brand: Maxxim
Model: Ferris
Item model number: 4S67T04405
Exterior: Machined
Manufacturer Part Number: 4S67T04405
Construction: 1-piece
Rim Diameter: 16 inches
Rim Width: 7 inches
Bolt Pattern (Number of Holes): 5
Bolt Pattern (Pitch Circle Diameter): 100 millimeters
Offset: 40 millimeters
I'd like to know if my tires are going to fit on those. Also I'd like to know if that's a good brand of rims or if anyone have them I'd like to know your opinions.
Thanks
Brand: Maxxim
Model: Ferris
Exterior: Machined
Rim Width: 7 inches
Thanks
Re: Help to choose the right rim
How old are your tires? When I was looking into buying rims I called all the tire places around me and they all said they wouldn't take the tire off of one rim and put it on another unless there were less than a couple hundred miles on them.
(Of course, i got lucky and scored a full set of HFP's with new tires on them for cheap, here is a link to my post:
https://www.civicforums.com/forums/1...good-deal.html
What brand and model tire is it?
You want to look up the tire specs like this:
http://www.tirerack.com/tires/tires....=055HR6EP422V2
Look under "rim width range". That will tell you. You should be fine, 7" is not to wide for that size b
i still keep my stock wheels for winter driving
choose your wheels for what you would like and make sure they fit.
wheels outlast tires, you know...
Balkos
Sep 11, 2015 11:39 PM
