8th Gen 2006 - 2011.
Coilover Decisions
Old Apr 24, 2013
ForeverSlow's Avatar
ForeverSlow is an unknown quantity at this point
Coilover Decisions
Im looking to get coilovers on my 2011 dx sedan. Ive looked at K Sport kontrol pro set or the Skunk2 Pro S. Its about a $150 difference. My friends say K Sport. Anyone else have pros and cons on the 2?
Old Apr 25, 2013
Gunner's Avatar
A true genius admits that he/she knows nothing.....CLOSED SAT/SUN
Gunner is a name known to allGunner is a name known to allGunner is a name known to allGunner is a name known to allGunner is a name known to allGunner is a name known to allGunner is a name known to allGunner is a name known to allGunner is a name known to all
Re: Coilover Decisions
Here are a few links to the info you may be looking for
http://www.8thcivic.com/forums/suspe...-06-civic.html
Skunk 2 review http://www.8thcivic.com/forums/suspe...v2-review.html
Old Apr 25, 2013
From what I understand the ksport seems like a better choice bc it has so many options of height and stiffness for them. The skunk2 thread every one was complaining about the bounciness of the ride. Stiffer setting means less bounce correct?
Old Apr 25, 2013
GolNat's Avatar
Prelude Owner
A softer setting will create a more bouncy ride at higher speeds, harder setting is generally a harsh ride at low speed and stable at high.
If you make the shock stiffer it will stop the spring from moving as much so it will be less bouncy.
Old Apr 25, 2013
So it basically comes down to finding what you drive most?
Old Apr 26, 2013
GolNat's Avatar
Prelude Owner
Correct. It is going to be a balance between comfort and performance. You may find that the roads you drive most ofter are really rough so you would want to dial to the softer side. You might not care about how rough the ride is because most of your driving is smooth highway.
Its also different between Coilover manufactures. Some are better for daily driving, others for racing. Whats rough to you may not be to me so it's hard to get a good idea of weather a particular setup rides nice or not until you try it.
Old Apr 26, 2013
TFMEX's Avatar
CO&CA
TFMEX is a jewel in the roughTFMEX is a jewel in the roughTFMEX is a jewel in the rough
I was lowered on Skunk2 Pro-S II's last year and I have to say i did enjoy them. Easy to adjust, solid construction and to me, good quality.
THEY ARE STIFF. its a rough ride, i sold them cause I could have my newborn ride in it without breaking her little neck LOL. I liked it personally and would have kept them if I didnt have the little one.
Also they went decently low. I would have preferred the rear to be lower and more adjsutable but it was low enough. ... i have pics in my build thread. keep in mind my tires are 205/40 which have a smaller overall diameter so if I was running the 215/45 they would tuck a little bit.
Old Apr 27, 2013
I think im going to go with the ksport just for a quick and easy adjust. From what my friend said I can adjust it while keeping the wheels on the car which is much easier for me. Thanks for all the help.
Tedverseti
Apr 23, 2020 01:45 PM
GolNat
Nov 27, 2018 03:32 PM
wingsfan19
Oct 1, 2015 03:45 AM
Tedverseti
Sep 29, 2015 05:41 PM
beanhead
Sep 24, 2015 12:04 PM
