DIY Tune-UP??!
DIY Tune-UP??!
What do i need to do to tune my 07 civic lx manual tranny?
I know you need to check
-air filter
-spark plugs
- all fluids
is there anything else?
and i was wondering how to check your clutch fluid? because i feel like its running low
-air filter
-spark plugs
- all fluids
Re: DIY Tune-UP??!
Look in your owners manual under maintenance.
"Tune up" is only a set of spark plugs and a valve adjustment, to be done when the maintenance minder comes up with a number 4. Usually around 105,000 miles.
Use the correct spark plugs:
NGK: IZFR6K-11S
DENSO: SKJ20DR-M11S
Descriptions of how to check the brake and clutch fluids are in the maintenance section of your owners manual also.
NGK: IZFR6K-11S
DENSO: SKJ20DR-M11S
A true genius admits that he/she knows nothing.....CLOSED SAT/SUN
Re: DIY Tune-UP??!
dont forget to check your cabin filter too.
these are often forgot about until the car starts stinking of dirtyness.
If you need OEM parts send me a PM. I work for a stealership and can get you a discount. we ship internationally too.
brake and clutch fluid resevoirs can be located in the engine compartment along the firewall. there is a min and max line. make sure your car is at normal operating temperature and check the levels. Also check and see how dirty the fluid is, may need to be flushed.
Ziggy1999
Oct 15, 2015 07:56 PM
meicalnissyen
Sep 25, 2015 12:12 AM
