Trailer Hitch
Trailer Hitch
Has anyone here installed a hitch on their Civic?
I have a 2012 EX and need to be able to tow a small utility trailer.
These Civics are good for towing like 1000lbs.
Who makes a good hitch?
Thanks!
Dave
Thanks!
Dave
Re: Trailer Hitch
I would be hauling small stuff and light loads of firewood on occasion. The car has the ability to tow, but is not likely designed to do a lot of it. So many new cars aren't rated or suggested to tow anything. It's really disappointing! You should not have to get into a truck to haul something that is not trunk worthy.
Re: Trailer Hitch
U-Haul? Hitches-R-Us? Yellow pages?
Every hitch I have ever seen on a small car looked really scary...But SOMEONE made it for the purpose.
Re: Trailer Hitch
With a rating of only like 1000lbs of trailer and cargo, owners have to use their heads. The car is not like a pickup truck, but at least it can handle doing a little hard work making it just more than a commuter car.
Re: Trailer Hitch
Re: Trailer Hitch
Um, I know my car is a '99 but I was looking through my owner's manual one day and saw ' Towing a Trailer'. I thought to myself Civic's can't tow trailers and this what it said,
You might want to check that out before you dump 5 years of warranty on your 2012.
Towing a Trailer
Your vehicle is not designed to tow a trailer. Attempting to do so can void your warranties.
Re: Trailer Hitch
I did this, also. I bought the hitch from Amazon.com and installed it myself in about 30 minutes. It's great for a bike rack, but I would not tow a trailer with it.
Re: Trailer Hitch
His argument is it doesn't matter whether 600 lbs of people inside the car or 600 lbs behind the car its the same effect on the vehicle.
I think its a bad idea. Thoughts?
Re: Trailer Hitch
Honda rates the car at 1000lbs of towing capacity. Many new cars do not have a rating from their manufacturer for one reason or another. Even a 1-ton pickup truck has some kind of towing capacity.
This was a selling feature for the car. At most, I'd be towing with a utility trailer a few loads of bark mulch a year and a small boat. The trick is not to overload the car's transmission and to get the fluid changed on schedule.
Re: Trailer Hitch
Are there ANY class 2 hitches for the 6th gen? I've seen plenty of class 1 hitches from etrailer (24677), u-haul and other brands. They hook up with 1 bolt on each side at the beams and then also gets connected to the tow hook in the middle of the back of the car with a u-bolt.
I'd probably want a trailer hitch that uses 2 bolts for each side. I haven't found any class 2 hitches but that doesn't mean a reputable company doesn't make them, or just a strong class 1.
I'm guessing the 8th, 9th have similar trailer hitch designs and so that's why I posted here.
No I'm not planning on towing anything huge, just want to be able to tow a small u-haul trailer at will when I want to.
EDIT:
class 1;
Draw-tite brand: 24677
Curt brand 1992-2000 all Civic 'cept Hatchbacks, Del Sol and Si: 11207
Hidden Hitch brand 1992-2000 all Civic 'cept Hatchbacks, Del Sol and Si: 60834
Reese brand: 77025 (I think)
Class 2; None
EDIT:
class 1;
Class 2; None
Last edited by danwat12345; Jun 23, 2012 at 05:28 PM. Reason: Removed bit about hidden hitch; not important
Re: Trailer Hitch
We carry trailer hitches. If you enter your vehicle it will sort the reviews (scroll down once on product page) based on your vehicle first. Hope this helps...
Skunkone
Sep 24, 2015 04:38 PM
