8th Gen 2006 - 2011.
Front two speakers quit working.
Old Nov 23, 2010
RyanHarp333's Avatar
RyanHarp333 is an unknown quantity at this point
I'm not really sure of the cause but my front two speakers quit working. Occasionally, the driver side works but only for a short time. I have an 06 civic 4dr and the stereo is completely factory. if anyone had any ideas on what this could be i'd very appreciative for some input.
Thanks in advance,
Ryan
Old Nov 23, 2010
Re: Front two speakers quit working.
almost always due to water damage. take the door panel out, cut and splice the wires directly to the speaker terminals, solder if possible. put some butyl around the open connection and then wrap electrical tape around that.
Old Nov 23, 2010
Kennykid2002's Avatar
Kenny the Ricer
95% chance it is water damage if it works intermittently.
If you open up the panel, might as well get new aftermarket speakers
Old Nov 30, 2010
Paul79UF's Avatar
Paul79UF is an unknown quantity at this point
Do you go through automatic car washes?
I was really surprised to see water droplets on the front door speakers after the car had gone through a gas station car wash earlier in the day.
Old Nov 30, 2010
every car gets wet behind the door panel. its even called the "wet" side for that reason. and there are drain holes so most of the water can come out. if you want roll down windows, it will happen.
Old Nov 30, 2010
Kenny the Ricer
And that's another reason not to go to automatic car washes
My main reason?
Effs up your paint job
Old Dec 10, 2010
Yeah, i definitely use automatic car washes... i guess i'll replace them kinda suck though..
Old Dec 10, 2010
thanks everyone for your replies seems to be water damage great analysis.
Old Feb 28, 2011
SubieSTI555's Avatar
SubieSTI555 is an unknown quantity at this point
Probably is water damage, I would go ahead and upgrade speakers and wiring while your at it
Old Jul 12, 2012
alsdock's Avatar
alsdock is an unknown quantity at this point
Question Re: Front two speakers quit working.
My front speakers barely make a sound when the volume control is cranked up. You think it's the speakers? How can I check? If so, what replacements would you recommend?
Jeffdp
Aug 5, 2015 11:38 AM
Galvezj11
Jun 17, 2015 04:13 PM
bsmiley
Apr 27, 2015 01:27 PM
ademarco6
Nov 16, 2001 10:19 PM
ademarco6
Nov 12, 2001 06:52 PM
