2006 Civic driver side window problem
my window on the driver side pop out during rolling up towards to the top ....no issue when rolling down....do i need a new window regulator or parts came loose ? pls
help ....thank you
help ....thank you
Re: 2006 Civic driver side window problem
remove the door panel and see what happened. most likely the window came out of its track. you can pop it back in but make sure to fix whatever caused it. alot of times the rail snaps off from its support beam. its very common.and while the panel is off and the window up, spray the tracks with silicone grease to help the window move easier.
i agree with him ^ its not that hard of a fix and is fairly common i have the 06 civic ex and mine did it too.. it took me a little while getting used to the window where u would hold the button to roll it all the way up and it would roll up to about an inch away from the top and then go back down to the half way position.. that tripped me out for a little bit
Xuhme
21
Aug 7, 2023 03:40 PM
ej8
Apr 13, 2015 06:36 PM
EXWisdom
Nov 5, 2001 10:24 PM
