How to adjust idle `07 civic
I have a 2007 Dx civic sedan.
When the A/C is engaged and the vehical is running, but at a stop, the idle falls below smooth idle and skips to the point of almost stalling.
Is there a easy way to adjust this?
Re: How to adjust idle `07 civic
idle is computer controled on most late model civics. there is an idle adjustment screw but its a bad idea to use it. usually if the idle cannot maintain itself under load, your IAC (idle air control) valve may be clogged with deposits. this is the sensor on the throttle body that has the two coolant hoses going to it. take that off and spray it with carb cleaner, i bet it will fix the idle drop.
mikemc422
Aug 9, 2018 05:41 PM
Civicchicky87
Idle Issues
Apr 22, 2015 07:16 PM
vtechcivic
Apr 21, 2015 06:58 PM
streetglower123
Apr 12, 2015 10:56 AM
