2006 EX Starts but will not run
Rep Power: 0 2006 EX Starts but will not run
Last Thursday my friends 2006 Civic EX wouldnt start. I was able to take a look at it for the first time today. The car will turn over just fine, will even start, but after a second or two it dies. The chime sound is strong as are all the dash lights. No check engine light at all. When I went to start it I can rev the motor a couple of times real quick before it dies. When it dies the fan will stay on. Checked the fuses, anything that said ign everything looked good. One thing I did notice, very soon after the car is turned off I can hear a light click sound coming from somewhere near the firewall on the drivers side. I'm told that when they tried to jump start the car last week that they were getting the same results, It would turn over and start but would not run or idle. Anyone with any ideas? Could it be a relay somewhere? If so which? where? Any help at all is greatly appreciated. Thanks
Rep Power: 0 Re: 2006 EX Starts but will not run
it just might be a bad ECU the click is normal sound but you might want to take the ECU to honda and run a diagnostic on it (or tow it in) but anyway good luck if the ECU has been altered than any warranty on it is good as gone but as for the click on the driver side there is nothing over there that would stop the car from running
Rep Power: 788 Re: 2006 EX Starts but will not run
sounds like a bad relay for sure, most likely the fuel pump is shutting off right after the car starts. otherwise revving it should keep the motor from dying.
dissconnect the battery and let the ECM (ECU) reset itself, new jeeps do this a LOT.
I was told my ECM (module?) was bad, but it only did it one time, never happened again.
I tried resetting the ECM. It didnt fix it. Havent had a chance to figure out where the fuel relay is yet, but I am guessing that would be the cheapest place to start if I were to just start replacing parts one by one. Where could I find the fuel relay? Anyone have a pic?
check owners manual. i dont have any info on the 06+ civics. its possible your fuse box is labeled and its in there. usually relays are either in the fuse box under the hood, or sometimes under the dash by the brake pedal and sometimes behind the glove box.
Live for the Twisties
Rep Power: 261 Re: 2006 EX Starts but will not run
It sounds like your crank shaft position sensor might need to be replaced, have you plugged the ecu into a code reader?
Xuhme
21
08-07-2023 03:40 PM
dragonsblood
04-27-2015 12:28 PM
black2k1vtec
12-06-2001 09:49 PM
