8th Gen 2006 - 2011.
disable seatbelt sound
Old Mar 17, 2009
cpE2envY's Avatar
cpE2envY is an unknown quantity at this point
i hate hearing that stupid seatbelt noise wen i dont have it on 2 go around the block 2 the store....is there anyway i can disable the sound? SOME1 HELPP MEEE.....thanx in advance
Old Mar 17, 2009
lordhelmet's Avatar
Re: disable seatbelt sound
Okay, here goes. This is my first DIY
1. Sit in the drivers seat.
2. Close the door.
3. Look to your left.
4. Grab the shiny thing hanging there (located on the b pillar)
5. Pull it across your chest down to your right hip.
6. Click the shiny metal piece into the receptacle that also contains the red release button.
7. Start your car.
Viola!! No more sounds.
(Steps 3-6 are optional for people who can't be killed but I take no responsibility for the gruesome death of those of us who don't fall into the immortal category.)
Old Mar 17, 2009
cpE2envY's Avatar
oooo thats wut that long shiny thing is for...thanks a lot..l0l
Old Mar 17, 2009
ci0vi8c's Avatar
ci0vi8c is an unknown quantity at this point
when u find out please let me kno....cuz it bothers the **** outa me..dam thing goin off b4 i even get out of the driveway! =(
Old Mar 17, 2009
lordhelmet's Avatar
Common sense indicates that the sounds happens when the buckle isn't buckled. There for there must be a sensor in the latch that says the belt is buckled. Therefore there must be a wire that goes to the latch. Find it and complete the circuit. Your car will always think your buckled in and thus no more sound.
Old Mar 17, 2009
ci0vi8c's Avatar
lol and when the wire is found and cut and if this really works.....then let me kno if things r runnin smoothly =)
Old Mar 17, 2009
its built into the gauge cluster. no way to remove without doing surgery and possibly breaking something. the easiest way is goto a junkyard and get a spare clip by itself and keep it near you. then plug it into the buckle when you dont use the main seatbelt.
Old Mar 17, 2009
lordhelmet's Avatar
Something has to tell the cluster that the buckle is buckled.
Old Mar 18, 2009
now its up to you to figure it out! ha. i bet its part of the srs circuitry. or maybe thru the seatbelt light? that would be pretty easy if it is. either apply a power or ground to the wire and the light turns off forever.
Old Mar 18, 2009
ci0vi8c's Avatar
Smile Re: disable seatbelt sound
haha that sounds way to complicated... ima just put my seatbelt on lol! =)
Old Mar 18, 2009
sjrd3387's Avatar
sjrd3387 is an unknown quantity at this point
there is 2 really easy solutions to all ur problems
1. there's a connector for the seatbelt under your seat so the seat can be taken out, find the connector and unplug it the ding and the light will go away
2. if u can't find the connector or are just too lazy, stick a knife in the seat belt connector and push down the lockin mechanism....it should click into place just like u put the seatbeat in it, therefore tricking the car to think u put it on
Old Mar 18, 2009
sethro's Avatar
sethro is an unknown quantity at this point
If you think thats annoying, you should hear the the sound the newer BMW's make. Holy mother.
Old Mar 18, 2009
sikassdrummer's Avatar
sikassdrummer is an unknown quantity at this point
could you post a pic of this connector , I am sure alot of people will see ,mostly airbag wired in (yellow) do not remove . A pic would be helpful
Thank You
pizzahutcombo
Suspension
Jul 13, 2021 09:41 PM
CraigW
Aug 18, 2015 07:06 AM
BootyDo
Jul 26, 2015 10:38 AM
Hqly2001
Jul 25, 2015 05:32 PM
