8th Gen 2006 - 2011.
Check Engine Light Won't go off
Old Oct 21, 2007
35neutral's Avatar
35neutral is an unknown quantity at this point
Question Check Engine Light Won't go off
My check engine light has been on (solid) for, like, 8K miles. Dealer keeps telling me that it's just the gas cap not having been screwed on tight, and that the engine is not putting out any codes, but I am getting more and more reluctant to believe this, especially since the "check gas cap" message has long gone. The check engine light remains though. I am at a loss to explain this, and have also noticed that my fuel economy has suffered a bit lately. The only thing that I am doing now that I wasn't doing on a regular basis before is topping off the gas when fueling up. Could that have messed things up? Any feedback is much appreciated.
Old Oct 21, 2007
FGCOUPE's Avatar
FGCOUPE is a name known to allFGCOUPE is a name known to allFGCOUPE is a name known to allFGCOUPE is a name known to allFGCOUPE is a name known to allFGCOUPE is a name known to allFGCOUPE is a name known to allFGCOUPE is a name known to all
Re: Check Engine Light Won't go off
dummie light for that goes off for emmision related things!
Gas cap not tight and/or seal not correctly seated
Charcoal canister
MAS/MAP sensor air leak and/or dirty
somethin like that, im making a complete Troubleshooting guide right now thats under construction on civicforums. So thatll help out somewhat....
Old Oct 22, 2007
35neutral's Avatar
Sweet, thanks. How easy is the charcoal canister to replace? Please let me know when your troubleshooting guide is completed, it looks impressive. Thx!
Old Oct 22, 2007
FGCOUPE's Avatar
i have more on the troubleshooting guide now, although i havent got to that point yet its coming along nice!
ive added more to the forums and whatnot
http://civicnation.12.forumer.com
Old Oct 25, 2007
SiMiranda's Avatar
SiMiranda is an unknown quantity at this point
What model year do you drive??? Do you know anyone with a programmer?
Old Oct 30, 2007
PLENTYofCARS's Avatar
PLENTYofCARS is an unknown quantity at this point
yeah sounds like it could be the charcoal cannister. weve been getting alot of newer cars coming in lately to my shop with evap codes, and a majority of them have been the cannisters. also the occasional maf/map sensors, or even an egr valve problem..hey for about 8000$ you can get the Snap On Modis scanner to check it out yourself!
Old Jan 12, 2008
///Bruce's Avatar
///Bruce is an unknown quantity at this point
Eight thousand miles and you're still driving the car without really knowing the problem? Get thee to a dealership and have it looked into before something REALLY bad possibly happens.
If you left the cap loose just once, eventually the check engine fault will turn the light off but keep the fault code in memory. Staying on this long indicates you still have an ongoing problem. Get it checked as soon as possible.
Xuhme
21
Aug 7, 2023 03:40 PM
hernandexz
Oct 28, 2021 10:52 PM
tylerginevan
Apr 27, 2015 12:29 PM
CascadiaBlue
Apr 18, 2015 09:13 AM
bahena08
Apr 11, 2015 05:09 PM
