8th Gen 2006 - 2011.
Bluetooth?
Old Oct 27, 2006
qdog123's Avatar
qdog123 is an unknown quantity at this point
Question Bluetooth?
Has anyone been able to get thier hands on a factory Bluetooth installation for the 2006 Civic? I read some other forums and found that this option is available in Canada, but no dice for the US. Just curious if anyone has tried to install the canadian solution. I have EX Coupe Navi if this helps.
Marc
Old Oct 31, 2006
Wadely's Avatar
Wadely is an unknown quantity at this point
No one hear at my work knows anything about it. And I havent heard anything from honda about it
Old Oct 31, 2006
qdog123's Avatar
Bummer
Thanks for checking into that for me! Maybe we'll see it in the future...
Marc
Old Nov 2, 2006
qdog123's Avatar
Here is the link
I found this link to Civic accessories and it lists the Blue Tooth as an option, but I do believe this is a civic not available in our market.
http://www.honda.ie/imgLib/honda2004...20Brochure.pdf
Marc
Old Nov 3, 2006
Syr_Civic_06's Avatar
Syr_Civic_06 is an unknown quantity at this point
I found this site:
http://www.hondahandsfree.com
Again, probably not for the US market.
Old Mar 7, 2007
Tazz2000's Avatar
Tazz2000 is an unknown quantity at this point
We'd have to run on the Canadian software, and see if the part numbers are the same to make sure the bluetooth unit would connect. Most likely more trouble than it's worth.
Old Mar 7, 2007
Alpha 5's Avatar
Those sites are for Honda of Europe.
Old Jun 27, 2007
southerndragoncivic's Avatar
southerndragoncivic is an unknown quantity at this point
Re: Bluetooth?
so far, the only thing i can tell you is that i have a Motorola integration kit that my dad and i installed (totally integratable if you get the nicer model) mine uses its own little speaker which we custom-mounted flush into the center console by the driver's footwell and we put the little control panel on the left hand side of the steering wheel and routed the wire along the rest of the wiring to where we mounted the actual bluetooth box, right underneath the gearshift (remember, cable-operated tranny) the only tricky part and possible reason to have a pro do it is putting in the mic b/c you have to run the mic wire up the A-pillar but can anyone guess what's in the A-pillar now? thats right, an airbag. also, you want to be careful of the doorseal, which i believe you have to pull back. Its a b#$%h to get back on to where it stays straight. I think this would work with most systems, just check compatibility or, better yet, get a motorola phone since they make some of the best bluetooth kits.
P.S. the nicer, higher-end kits integrate completely into the car, utilizing the stereo speakers rather than a dedicated (and dingy) mono speaker.
burnyd
ECU Fried
May 24, 2018 10:44 PM
SammySC
121
Apr 7, 2017 07:43 PM
alaga
Feb 28, 2016 02:19 PM
lolhowell
Photography & Videography
Sep 11, 2015 05:09 PM
Donahue
Sep 8, 2015 09:00 AM
