? about straight or test pipes
Old Apr 8, 2003
d17a2outlaw's Avatar
d17a2outlaw is an unknown quantity at this point
i was wondering if any one here is running a straight or test pipe. and will it help get hp gains.
Old Apr 8, 2003
Dr5D's Avatar
i dunno, but it would be real loud
Old Apr 8, 2003
david02civic's Avatar
I'm The Shit
david02civic should not be trusteddavid02civic should not be trusteddavid02civic should not be trusteddavid02civic should not be trusteddavid02civic should not be trusteddavid02civic should not be trusted
My friend has an 02 EX with an intake, header, and straight pipes. I have a DX with no engine mods whatsoever, both 5 speed, hes a pretty good driver and i am also one, and I beat him from a roll ,and a dead stop, i think the straight pipes killed him cause he used to be able to beat me before he got them done, mayabe a coincondece but i dont knwo, my .02
Old Apr 8, 2003
Roy's Avatar
Roy
Roy is an unknown quantity at this point
For sure you will net a gain from a test pipe, garunteed. As for a stock civic beating the other modified one, not sure what happened there. Try it again. I got one.
Old Apr 9, 2003
ViNRoCk8's Avatar
#1 S2000 Fan
Well if the testpipe is actuall too big........
it would cause a loss of power.....the air would not flow correctly
Old Apr 9, 2003
thanks for all the replies guys. i was thinking of getting a test pipe but when i went to CMI (a drag race event held in sacramento) every car was running open header, would that be good to run on the tracks for our civics?thanks in advanced.
Old Apr 9, 2003
xblkcivicx's Avatar
xblkcivicx is an unknown quantity at this point
Open header would be rediculously loud. I have a hi-flo cat, and it definitly opened up the exhaust to flow better. It all depends on what size piping you get. But it will give you gains over keeping your cat, to answer your question....good luck.
Old Apr 15, 2003
old beater's Avatar
old beater is an unknown quantity at this point
you lose alot of low end with a testpipe my 60ft times at the track went from 2.3 to 2.7. my 1/8 mile times stayed the same and my 1/4 times fell about .2 average. blkcivic: where did you get your hi flow cat from?
Old Apr 15, 2003
K@mik@ze's Avatar
K@mik@ze is an unknown quantity at this point
Our engines and the engine management system are designed around the built-in backpressure from the stock exhaust system. I second the fact that you need a certain amount of backpressure if you want to keep any of the low end power (honda's already are weak in that area). Forced induction would help tremendously with a high-flow exhaust.
Old Apr 15, 2003
RiceBuRNeR's Avatar
Turbo Member
Trust me, I have a straight through exhaust and you loose low end. The car lags badly untill over 5,000 rpms. Im thinking about welding a "tourque stuffer" into the collector to get some low end back.
Jul 12, 2015 11:54 AM
Bounddyy
Jul 8, 2015 11:22 AM
Youshoe
Air Conditioning
Jul 8, 2015 09:49 AM
Causemo
Jul 5, 2015 06:42 AM
cukaracha
Jun 8, 2015 05:41 PM
