connecting neons to alternate source
Old Mar 23, 2003
ponyboy's Avatar
ponyboy is an unknown quantity at this point
ive got 2 neons under my driver and passenger seats. they are connected to my ciggerate lighter through a quad outlet. is there any other way i can conncect them like to my battery or something because the wires look really nasty like that.
Old Mar 24, 2003
blouisgod's Avatar
Life Begins > 6800rpms
you can use a dead fuse slot, i think #18 where the day time running lights would go if you working on an A-spec
Old Mar 24, 2003
Chrisman8995's Avatar
Chrisman8995 is an unknown quantity at this point
or you could connect the power wire to another source such as the radio....and put a switch within the wire to power the lights on and off
Old Mar 24, 2003
EnProceso's Avatar
you can hook them up directly to the battery. run a 12 gauge wire from the battery, have an inline fuse about 10 inches away, through your firewall and to whereever your switches are. or what i did was splice into my cig. lighter wire behind the dash and use that. i have neons under the seats, dash and in the air vents. the hard part is figuring where you want the switches, i have my in front of the cupholders in the console but i have seen others that have them in the dash in the empty spot where the 2 blank panels are and others have them in the glove box, guess it depends if you want them visible or easy to turn on and off. if you like i can email you pictures of my set up, you can also go to the www.streetglow.com messege board, you'll find tons of help there. have fun.
Old Mar 24, 2003
sg2kca's Avatar
sg2kca is an unknown quantity at this point
I would like to see pictures if you don't mind
Old Mar 25, 2003
iluvbritney's Avatar
iluvbritney is an unknown quantity at this point
cut off the cig connector, separate the two wires...then connect one and ground one
Old Mar 27, 2003
sador's Avatar
sador is an unknown quantity at this point
also you can do it using a relay(SPDT) and wire like this
#86 ground
#87 12volt
#85 from you parking lights,remote turn on,or any source you choose to use
#30 to positive (+) from your neon
and that's it.
Old Mar 28, 2003
EnProceso's Avatar
these are my switches. when i get an underbody kit, i gonna use one of those blank panels next to the cig. lighter and install the switch for it there. and since i have nothing but blue neons, i'm also gonna switch the switches to all blue, dont know why i got different colors to begin with! its very simple to do, i took off the console, installed the lights, stuck the transformers under the dash and hide the wires. i spliced into my cig. lighter wire to power them and used a nut and bolt under the console as a ground. it was a one day job. i'll have to take a picture of it all lite up one day...i mean night.
OptimisticWay
46
Oct 15, 2015 02:16 PM
jzhartman
22
Jul 23, 2015 10:42 PM
Smokahontas123
Jul 22, 2015 10:07 PM
Jul 12, 2015 11:54 AM
robbie374
Jul 7, 2015 02:56 AM
