Headlight Removal...
Old Mar 18, 2003
Macko's Avatar
Macko is an unknown quantity at this point
Question Headlight Removal...
Okay... i searched... but then realized it was gonna take forever going through the results...
But does anyone here remember that post about removing yout headlight without removing bumper?
or
does anyone know if it's even remotely possible to remove the headlight without the bumper...
I've changed my headlight before, but dun wanna go through the whole process of taking off the front end...
Old Mar 18, 2003
GanariGuY's Avatar
GanariGuY is an unknown quantity at this point
sorry man...... unless you didn't bolt the bolt that was under the headlights..... you must remove the bumepr to get two them bolts......
Old Mar 18, 2003
Elite's Avatar
Elite is an unknown quantity at this point
yup I did what GanariGuY said I removed the bolt just in case I needed to remove it for later use cuz sometimes removing the bumper can be a bish and I am lazy for the most part
Old Mar 18, 2003
Macko's Avatar
Wait if i remeber corredt ly ther is a slot in my underbody splash panel where teh bolt on the bottome is close by... do you guys think i can stick like 20 lil socket extensions and get to the bolt? LOL
Old Mar 18, 2003
GanariGuY's Avatar
hahahaha...... i guess go for it.....
But leavin your bumper on and off is dangerous..... you might end up scrapin your fender like i did once.... almost mad me cry..
Also with fiberglass bumpers.... takin it on and off might make the fitment loose and you will get gaps in your bumper
Old Mar 18, 2003
Weaponx12o's Avatar
i took my headlights off w/o removing the bumper hehe. i had no choice, i couldnt fit a jack under my car so i couldnt take out the 2 screws with a screwdriver. and i didnt have any pieces of wood to roll over either. all i did was take the plastic pins on the bottom on each side. then i took off the clips with the socket wrench. make sure the pins at the top are off, then pull away i had a friend hold down the bumper so it wont keep coming back up. make sure you dont bend too far!! or else you'll break something, but from what ive seen. the thing the bumper's attached to seems pretty strong. but yea.. try at your own risk hehe
Old Mar 18, 2003
Vinnie's Avatar
Vinnie should not be trustedVinnie should not be trustedVinnie should not be trustedVinnie should not be trusted
Seems difficult to remove headlights w/o taking off the bumper. But you dont necessarily need to take off the entire bumper. You can just remove the front so its kind of still attached. I did this while clearing my headlights realli not hard, a bit easier than taking the whole thing off. haha
Old Mar 18, 2003
iluvbritney's Avatar
iluvbritney is an unknown quantity at this point
nothing is impossible but that one buld right under the headlight is ur problem....i'm not saying its impossible but its pretty hard to take that off unless you have the tools
Old Mar 18, 2003
born2xLr8's Avatar
I did it without taking the bumper off. It's not hard at all. As a matter of fact, I'd say it's easier because you don't have to deal with taking off and putting on the bumper. Just take the 4 plastic clips and the 2 screws in the fender well off then peel the bumper down.
Old Mar 18, 2003
7thGenerasianCivic's Avatar
You could just take out the clips on top and pull the bumper down...but might bend the underpart a little though. That's what I did when I cleared my lights for the first time...don't think I damaged anything...
Old Mar 19, 2003
RoadRunner's Avatar
you can't get to the bottom and side screws that hold the headlight bracket in place, unless you remove the front bumper ..... sorry pal. Your gonna have to do it the hard way.
Old Mar 20, 2003
tAkTicS's Avatar
tAkTicS is an unknown quantity at this point
ok about bumper removal... how many screws total are there, and where do they all go.
because i have two left over from clearing my headlights a while ago and i cant figure out where to put them. so far the bumper has not sagged at all and is not loose so they cant be that important, but just to make me feel better i want to put them in.
Old Mar 20, 2003
doctor's Avatar
Type-Race
doctor will become famous soon enoughdoctor will become famous soon enough
Just look under the bumper and youll see where youre missin the screws. Two screws+four clips
Old Mar 21, 2003
Booohahaha's Avatar
BAD MON
yea.. it should be a big tight the first time taking it off
but after the first time it should be like a peel on and off anytime u want!!!
meicalnissyen
Sep 25, 2015 12:12 AM
rnaodm
Sep 21, 2015 12:42 PM
shaejb15
Sep 12, 2015 01:02 AM
Bricoleur
Sep 9, 2015 12:23 PM
MamaBear2015
Sep 4, 2015 09:04 PM
