What HID Bulb Fit into TYC PROJECTORS?
Old Mar 18, 2003
netcbc's Avatar
netcbc is an unknown quantity at this point
I wanted to get D2S HID bulbs, but is it only 1 size and would it fit?
As for H1 HID bulbs, will it fit, the HID conversion type bulbs?
Old Mar 18, 2003
Weaponx12o's Avatar
imo, i wouldnt put HID bulbs in tycs. they're projectors and will probably blind the hell out of oncoming traffic hehe. plus the wattage might be too much. there are some members here with HID bulbs though. maybe you can ask them. the H1 HID bulbs should fit, i dont understand why it wont.
Old Mar 18, 2003
netcbc's Avatar
the conversion set kind have a shielding on it thats why, like so
Old Mar 18, 2003
Voiceofid's Avatar
End Bringer
actually, many people say it's better use hid in tyc projectors than in the stock headlight assembly, because projectors are designed with a sharp cut, while deflector type housing is a cluster that slowly fades as it leaves the center. a couple mebers converted the tyc lens into the audi a8 lens before adding on hid. but i think h1 is correct
Old Mar 18, 2003
netcbc's Avatar
Yap I dod want to put HID in my TYC Projectors, but my problem is that shielding thing, do people still stick it in with the shielding on? cause that shielding is suppose to be for regular housing not projector housing
Old Mar 18, 2003
R1Style's Avatar
HID's run colder then regular halogen bulbs. So no, you won't have to worry about melting your housing or wires.
As for the shield, you won't need it. Your TYC projectors should already have a shield on the inner upper half the the projector lens so you could just plug them in and it'll work fine. H1's are correct.
Old Mar 18, 2003
netcbc's Avatar
Yeah but then should i crack the shielding off? that doesn't seem right, thats why wondering if people got D2S HID bulbs and if they come in h1 size
Old Mar 18, 2003
dragoon's Avatar
the "H1" HID bulbs are D2S or similar with the custom molded H1 socket. if the bulb fits, don't crack the shielding. and for gods' sake PLEASE aim your projectors properly especially if you have HID!
Old Mar 19, 2003
netcbc's Avatar
This is the kind of information i'm looking for, thanks!
Yap it'll be aimed properly for sure
Old Mar 19, 2003
CarbonFly's Avatar
I've heard that "H1 HID" bulbs are too long for the TYC projector housing. I'm not sure, but I thinkin that's that Unleaded said.
Old Mar 19, 2003
netcbc's Avatar
who was the one who did the a6 retrofit audi projector things? he's like an HID expert, i can't find his posts anymore
Old Mar 24, 2003
Saj's Avatar
Saj
Saj is an unknown quantity at this point
Question
ok guys now im really confused, will it work or not??
------>Read This
Old Mar 31, 2003
netcbc's Avatar
don't think its that big of a deal? seems pretty good when ppl use it
Old Jun 11, 2003
SLAMMED01CIV's Avatar
SLAMMED01CIV is an unknown quantity at this point
Ok I'm going to clear this up. I have a set of Xenon H1 7000k HID's in my TYC projectors. Yes it is H1 HID bulbs. No they are not too big for TYC projectors. Yes you will still have a sharp cut off point. The light output is unbelievable!!! So bright. I had to do some modifying to fit the bulbs though. The HID bulbs have that little "rod" that comes off the side. Because of this "rod" I had to make the bulb housing in the projector bigger. I used a drill and cut out a little space at the bottom of the bulb housing so it would fit. Also I had to modify the rubber water resistant cover that goes over the back of the bulb housing. I had to cut a small hole so that the supplied wire plug would fit.
It's really complicated to explain.
mac25
Aug 21, 2015 11:14 PM
bmwstar98
Aug 16, 2015 02:28 PM
j-chest
Aug 11, 2015 02:26 PM
j-chest
Jul 31, 2015 01:18 PM
EM_WON
Jul 22, 2015 06:49 PM
