Swap...
Old Mar 12, 2003
CivicMexicano's Avatar
El Pinche Turbo Mexicano
CivicMexicano is an unknown quantity at this point
Swap...
i know, i know this subject has been dealt with before, but i've never goten a straight awser, well you see here in Mexico we do not have the RSX, so it woudl be easier to find the engine from the CR-V or the Accord, but lets say you have the engine, then what
will the HaSport mount work with the K24 engine??
if you get the engine from the CR-V what tranny would U use since the only model available is AWD?
will the wiring be more difficult than the one from the RSX??
thanxs for your awsers....
Old Mar 12, 2003
Gryphin's Avatar
00 Hatchback Owner
hmmm , well it would be a BITCH to make the civic awd, since its FWD, but you could always order the RSX engine, and have it shipped to, you.
Old Mar 12, 2003
well the inly option would be buy the engine in the US and have the swap made over there or get the engine here and still go to the US to get the swap done
Old Mar 13, 2003
jefff's Avatar
jefff is an unknown quantity at this point
The K24 should fit from what I'm told. should link up the the TRSX tranny if you want. Most if the after market mods for the K20 should also fit the K24 but not for sure. Check out www.hondaswap.com if you want more info.
Old Mar 14, 2003
Jaykuai's Avatar
ish...
i also wanna know if the k24 is usable, as civic mexicano i live in mexico and i cant get a rsx engine..
or maybe the coupe engine.. vtec 3.0 i dont know what model is...
Old Mar 17, 2003
mohawkboom's Avatar
the K24 blocks will fit no sweat,,same mounts as the k20, there's slight differences though as to where the Power steering pump and A/C compressor is located on them. No Biggy. The problem is the K24's (accord and TSX) tranmission housing is larger than the K20 for some reason. You'd need an RSX/Si tranny. A Base RSX 5speed's gear ratios would work really well with the torque of a K24 and keep everything relatively bolt in. Remember as well you need to replace the radiator and you need an RSX crossmember for the swap, not just the mounts.
Cheers
Mohawk
civicnewb
75
Feb 8, 2013 02:06 PM
switch93
Jan 30, 2012 05:42 AM
em2_jdmboy
Florida
Jan 21, 2010 10:47 AM
Redviking
Sep 8, 2006 01:18 PM
AznSaint
May 28, 2006 09:30 PM
