Painting trim peices question
Old Mar 11, 2003
OmegaStauf's Avatar
OmegaStauf is an unknown quantity at this point
I searched but I didn't find any answers.
Has anyone finished off their painting with a clear coat. I see the DIY doesn't say whether or not it is a good idea.
What do you guys think?
Anybody done it?
Thanks!!!!!!!!
Old Mar 11, 2003
Samari's Avatar
yes, it gives it a nice protective, shiny coat. You should clear coat.
Old Mar 11, 2003
blackbullet's Avatar
The Legend
Do it!!
Old Mar 11, 2003
Deceit's Avatar
Deceit is an unknown quantity at this point
2 coats of clear =
Old Mar 11, 2003
OmegaStauf's Avatar
Thanks for the input!!!! [IMG]i/expressions/face-icon-small-smile.gif[/IMG]
Old Mar 11, 2003
Dr5D's Avatar
btw, what parts are you thinking of painting?
Old Mar 11, 2003
OmegaStauf's Avatar
Quote
[hr]Originally posted by: Dr5D
btw, what parts are you thinking of painting?[hr]
Vents, center peice and the two peices in the center that run between the seats.
Old Mar 11, 2003
CivicRicer02's Avatar
CivicRicer02 is an unknown quantity at this point
sweet i am thinkig of getting a carbon kit
Old Mar 12, 2003
OmegaStauf's Avatar
I had the factory kit but I don't like it.... very crappy. Silver kit that is.
Old Mar 12, 2003
MaddonE's Avatar
MaddonE is an unknown quantity at this point
painted some trim pieces red and waited for it to dry, but when i put the clear coat on it turn the red into like a pink color. i say no go on the clear coat, just my .02
Old Mar 13, 2003
jefff's Avatar
jefff is an unknown quantity at this point
You have to give it a good amount of time between the paint and the clear coat and you have to make sure that thye clear coat is ok for the type of paint your using, but it should work fine. Saves you from having to re-paint any time soon.
I say Go with at lease a couple coats of clear coat. But again that's just My Opinion.
EDIT: make sure to use a few light coats of clear not fewer heavy coats.
Good Luck All!
Old Mar 13, 2003
andyman97's Avatar
Turbo Guru
Ok, the long and short of it all is that if you use spray paint, it's very thin, very cheap quality. Think about it, look at the tip of a spray can. It has a tiny opening in it which doesn't allow much paint to flow out of it therefore the paint is very thin. That's why you will see runs much more often with this type of paint and that's why it's so inexpensive. It works for a while but eventually if your car is a daily driver, there will be some damage to the paint. Now one way to solve the problem is to use a good spray gun and some professional interior paint and well prep the surface, finishing it up with some pro quality clear for interior as well. Granted you may still see damage after alot of wear but not nearly like you will if you use a spray can. Another thing you can do is just use the spray can and follow it up with some professional quality clear coat for interiors.
Now you can get the job done just by using spray cans but ask anyone who's done this on a daily driver and ask them how well it's held up or whether or not they've had to repaint it. My bet is that the consensus is that it hasn't held up very well or it's been resprayed. So it comes down to the question of asking yourself if you'd rather not spend much money and have a mediocre paint job that you always worry about or you can spend a few bucks and get it done right. Good luck with it.
Amulon
Aug 18, 2015 11:03 AM
masongap
Aug 4, 2015 09:20 AM
jpandjf
Aug 3, 2015 05:02 PM
jedi
Aug 3, 2015 04:26 PM
BootyDo
Jul 7, 2015 06:06 AM
