Thoughts on Custom Supercharger
Old Mar 11, 2003
AEMcivic's Avatar
AEMcivic is an unknown quantity at this point
Ok, I searched and found a few threads on superchargers for the D17. The most informative post was by Likeweeeee when he proposed the idea of extending a rod accross the engine bay that would support the pully system. (won't get into detail, but I'm sure most of you know what I mean) I also saw posts from people saying that it wouldn't be worth it because we have FWD cars (don't know what that's all about), and that it would take away too much power. Now, I'm just looking for ideas for a custom SC setup. I know that we'd have to get a custom intake manifold made, design some sort of pully system, and relocate a few things such as the battery. But for those of you that have thought about this, or have knowledge of SC setups, please post your views. I'm just curious as to how this could be done (b/c I know it can be done). Also, has anyone successfully supercharged a 7thgen?
Old Mar 11, 2003
mykungfuisthebest's Avatar
mykungfuisthebest is an unknown quantity at this point
anything is possible, but turbo is cheaper, and can produce way more power, although is riskier, and a bit more complicated
superchargers are good though, i just think they are much more functional on high displacement engines, turbos can pull more out of the d17 i mean look at the few turbo on this site, for around 5 grand(how much my parts are costing IF you DIY) there getting around orabove 200 hp(with fuelsys and engine mods 250 possible ez)
no one here has supercharged d17, as far as ive heard ive been on every day for months
as for people that compain about fwd and how slow 7th gens are and how no one needs a wing or no power mods do anything on our cars
there isnt much point of being here then lol. there are plenty of superchargers made for other civics and fwd cars and they work great if thats what you want
Old Mar 11, 2003
Boilermaker1's Avatar
Jap-Euro Fusion
The bar across the engine bay is has been done before. The Comptech kit for the Accord V6 has a drive shaft that goes across the engine bay. The thing with superchargers is they take HP to make HP whereas turbos are free HP since they run off exhaust gas. So supercharging a 4 banger isn't as effecient in most cases because they don't have much power to give in the first place. I don't see why a centrifugal supercharger (like a Vortech) couldn't be adapted to work in our cars. Yes you'd have to move the battery, but I don't think you'd have to change the vertical throttle arrangement.... since there's a pipe between the S/C and the throttle. I would get a stronger manifold though, I wouldn't trust the plastic one for too long. And yes, you'd have to run a drive shaft across the front of the engine to get to the pulleys to power it. It would get cramped, but if you wanted to pull it off, I think you could. Take a look at the Vortech B16 kit.... I think it would end up being similar to that one.
Old Mar 11, 2003
Spider883's Avatar
9K Redline Owns U
hey ben get me a centrifugal supercharger and u know ill get it on there some how
Old Mar 11, 2003
Diemos's Avatar
Diemos is an unknown quantity at this point
Quote
[hr]Originally posted by: Boilermaker1
The bar across the engine bay is has been done before. The Comptech kit for the Accord V6 has a drive shaft that goes across the engine bay. The thing with superchargers is they take HP to make HP whereas turbos are free HP since they run off exhaust gas. So supercharging a 4 banger isn't as effecient in most cases because they don't have much power to give in the first place. I don't see why a centrifugal supercharger (like a Vortech) couldn't be adapted to work in our cars. Yes you'd have to move the battery, but I don't think you'd have to change the vertical throttle arrangement.... since there's a pipe between the S/C and the throttle. I would get a stronger manifold though, I wouldn't trust the plastic one for too long. And yes, you'd have to run a drive shaft across the front of the engine to get to the pulleys to power it. It would get cramped, but if you wanted to pull it off, I think you could. Take a look at the Vortech B16 kit.... I think it would end up being similar to that one.[hr]
If you say you lose HP from superchargers then the same could be said about turbos, because they put back pressure on the exhaust. Superchargers also require less work after they are installed and are much better suited for daily drivers.
Old Mar 11, 2003
MadWheel's Avatar
Premium Boosted Member
Yes but back pressure on an engine originally without forced induction can help in some respects by allowing the motor at lower rpms to make more tourque. This helps rev a lil quicker, spooling up the turbo.
Go for it man!! A supercharged 7thgen on this site would be great. Instead of one day having a turbo forum, we could have a forced induction forum. Either way good look, boost is definately the way to go. TAKE A MOTHER LOAD OF PICTURES. We all wanna see this baby go down.
Old Mar 11, 2003
renagadecivic's Avatar
renagadecivic is an unknown quantity at this point
Quote
[hr]Originally posted by: mykungfuisthebest
anything is possible, but turbo is cheaper[hr]
True but turbo requires so much more maintenance than a supercharger that It may be worth the price.
Old Mar 11, 2003
4drcivic2k1's Avatar
Turbos, Engines, Chassis and Suspension Tech
4drcivic2k1 is an unknown quantity at this point
under boost turbos will not add backpressure....and no you dont want backpressure AT ALL. you want exhaust velocity. people think that because you stick big pipes on you lose torque, which you do, because you lose velocity because you are pushing the same amount of gas through a large pipe. take a straw, blow down it, feel how fast it comes out. take a 2" dia pvc pipe and blow down that. exactly.
Old Mar 11, 2003
white2K2EX's Avatar
I sure wish my car was newer
If someone built a successful kit, it wouldn't take much convincing, other than safety issues, for me to buy it. I'd much rather have an SC instead of a TC coz this is my daily driver.
Old Mar 11, 2003
dragoon's Avatar
hm.. wonder if there's a way to rig the JRSC from the 00 SI, my friend's got one she'll give to me because she's made of money [IMG]i/expressions/laugh2.gif[/IMG]
Old Mar 11, 2003
cdmx's Avatar
Why exactly is a supercharger better than a turbo, and why would a turbo require lots of maintenence if i was only doing 4-5 psi daily and 8 when i really needed it, sometimes excessively cause you know you couldnt put it on low boost all the time[IMG]i/expressions/demon.gif[/IMG] Wouldn't the engine still last pretty long? I was told that the block was tested to handle up to 12psi
Old Mar 12, 2003
03_silver_ex's Avatar
03_silver_ex is an unknown quantity at this point
Quote
[hr]Originally posted by: cdmx
Why exactly is a supercharger better than a turbo, and why would a turbo require lots of maintenence if i was only doing 4-5 psi daily and 8 when i really needed it, sometimes excessively cause you know you couldnt put it on low boost all the time[IMG]i/expressions/demon.gif[/IMG] Wouldn't the engine still last pretty long? I was told that the block was tested to handle up to 12psi[hr]
12psi
Old Mar 12, 2003
Jap-Euro Fusion
Quote
A supercharger isn't necessarily "better" than a turbo... they just have different advantages. Superchargers provide instant boost since they're belt driven. So there isn't any lag. Turbos need to spool up before they're effective so unless you have a very small turbo, it's going to take a while to spool up so if you commute and sit in traffic, you'll have no low end, but can provide shitloads of high end punch. As if we have much low end as it is, but ideally, you'll lower the compression, which will pull some more low end away. So crawling along with a turbo could prove to be a pain especially since you've probably got a free flowing exhaust now to help the turbo out (bye bye more low end). Having the S/C and instant boost the second you step on the gas is helpful in this situation since it gives you the power you need. Since a lot of people use their cars as daily drivers, the supercharger would be a better alternative for a lot of people.
I don't remember why the turbo needs more maintenance... someone else is gonna have to answer that.
Old Mar 12, 2003
AEMcivic's Avatar
The reason turbos are a little higher maintenance is because they are integrated into your exhaust system. A turbo also consists of two compressor housings, and two impellers which are joined together......as opposed to a supercharger which consists of one compressor housing and impeller. Not only does the turbo have an extra turbine working on the exhaust side, but this turbine (along with the whole turbo) is exposed to excessive amounts of heat, which in turn cause more wear and tear on the impellers and bearings. And wear and tear lead to oil leaks, exhaust leaks, and other problems, which require you to make adjustments, or rebuild the turbo. Superchargers, on the otherhand, are belt driven and have one turbine that involves the intake system only, which is cooler air. So you have the cooler operating temperatures, and the less complicated assembly of the supercharger, therefore there is less wear, tear, and maintenance. (or something like that...)
Old Mar 12, 2003
MadWheel's Avatar
Beat me to it. It's all about temps and reliability.
Old Mar 12, 2003
AEMcivic's Avatar
Hey, look. I found a picture of the Vortech SC on a B16.
Old Mar 12, 2003
THEANTIRICEST's Avatar
Premium Member & 1 Millionth Poster!
THEANTIRICEST has disabled reputation
Quote
[hr]Originally posted by: white2K2EX
If someone built a successful kit, it wouldn't take much convincing, other than safety issues, for me to buy it. I'd much rather have an SC instead of a TC coz this is my daily driver.[hr]
YES!!!! Let's begin the custom SC revolution!
carid
Nov 7, 2015 01:46 AM
sch2cm
Jul 21, 2015 09:58 PM
cizsak
Jul 21, 2015 03:39 PM
liagreenhalgh92
Jul 21, 2015 01:31 PM
beeemerdude
Jul 10, 2015 09:22 PM
