turn signal
Old Feb 22, 2003
jrock2324's Avatar
jrock2324 is an unknown quantity at this point
turn signal
My turn signal on the right side does not work. It only come on when the headlights are not on. But when I turn the headlights on the right signal do not work. It only work when the headlights are not on.[IMG]i/expressions/face-icon-small-confused.gif[/IMG]
Old Feb 22, 2003
emmc's Avatar
Venezuelan Member
emmc is an unknown quantity at this point
are u using projectors or the stock healights???
Old Feb 22, 2003
jrock2324's Avatar
stock headlights
Old Feb 22, 2003
injencivic's Avatar
injencivic is a glorious beacon of lightinjencivic is a glorious beacon of lightinjencivic is a glorious beacon of lightinjencivic is a glorious beacon of lightinjencivic is a glorious beacon of light
turn signals are double filament which means they work when turned on and when turn signal is activated, go buy a new bulb. thats what it sounds like to me.
INJEN
Old Feb 22, 2003
jrock2324's Avatar
But all my bulbs are fine. I check all of them. [IMG]i/expressions/face-icon-small-confused.gif[/IMG]
Old Feb 22, 2003
OmegaBlue2k1's Avatar
OmegaBlue2k1 is an unknown quantity at this point
If you have an Injen CAI you have to go back in there and retighten your grounding point where all the lights end up in a harness, I found that if you just flip that harness over so the prong points outward instead of into the straddling hole youll get a better goround out of it. this happened to me sevearl times with my Injen CAI and it pissed me off every time.
Old Feb 22, 2003
jrock2324's Avatar
Quote
[hr]Originally posted by: OmegaBlue2k1
If you have an Injen CAI you have to go back in there and retighten your grounding point where all the lights end up in a harness, I found that if you just flip that harness over so the prong points outward instead of into the straddling hole youll get a better goround out of it. this happened to me sevearl times with my Injen CAI and it pissed me off every time.[hr]
I do have the injen cai. And I did do the same thing you did. But still no turn signal
Old Feb 22, 2003
injencivic's Avatar
switch sides on where your ground is. mine had that and i switched it to the other side, everything is fine now
INJEN
Old Feb 22, 2003
jrock2324's Avatar
Quote
[hr]Originally posted by: injencivic
INJEN[hr]
So all I have to do is turn the ground wire over and that's it.
steveneddy
May 19, 2015 02:39 PM
shaejb15
Apr 26, 2015 07:44 PM
Fastfebur
Apr 22, 2015 01:37 PM
wawacito
May 14, 2002 07:33 PM
my2k1vic
Jan 8, 2002 08:31 PM
