help: interior paint
Old Feb 19, 2003
01EMCVC's Avatar
01EMCVC is an unknown quantity at this point
What should i use to remove paint from an interior piece that was painted, i know paint thinner will turn the plastic into soup, i was told to use acetone(nail polish remover), but i was wondering if anyone knew, any help is greatly appreciated.[IMG]i/expressions/beer_yum.gif[/IMG]
Old Feb 19, 2003
ak's Avatar
ak
Retired Mod
ak can only hope to improve
Oh man, i did this today thanks to andyman97's help!
Things you need:
1. 1 sheet of 400-500 grit wet sand paper
2. paint
Simple steps:
1. Soak a 3"by3" section (or whatever size you like) into a water bucket for a few minutes...
2. Sand the plastic piece while keeping the sand paper wet at all times . Have patience.. you might need to put some muscles at times, but it works.
DO NOT USE PAINT THINNER. After that...it should all be black and ready to be repainted.
Spray 4-5 layers of paint (wait 10 minutes between each coats) and apply 2 layers of Clear Lacquer (aka clear coat) and let it dry for 2 hours.
Put it all back together, and enjoy!
Old Feb 19, 2003
CarbonFly's Avatar
I just painted my pillars.
Items needed:
- Plasti-kote White primer
- Plasti-kote Vinyl paint(this will not crack or peel
Steps:
1. Give 2 layers of the primer
2. Let dry
3. Give 3-4 layers of the color you want
4. Let dry
5. Clear Coat
Old Feb 20, 2003
andyman97's Avatar
Turbo Guru
Quote
[hr]Originally posted by: ak
Things you need:
2. paint
Simple steps:
Put it all back together, and enjoy! [hr]
Hehehe, nice work bro, lol. This is exactly what you should do man. As far as primer goes, I wouldn't recommend using it for a few reasons.
1: Primer is used for a few things. First it's used to treat metal so as to prevent rust. You aren't painting metal.
2: Primer is used to fill in scratchesand leave a sandable surface. If you wet sand the pieces you shouldn't have any scratches that the paint won't fill.
3: You don't want alot of thickness on the plastic. Too much can cause cracking or flaking.
And one thing that ak left out....once you have sanded it down, if you are going to repaint it you should use a scotch brite pad to scuff up the surface, it gives the paint something to hold onto and helps prevent flaking.
Old Feb 20, 2003
andyman97's Avatar
Turbo Guru
Holy **** bro, when did you become a mod? LOL, I missed that, you never told me [IMG]i/expressions/face-icon-small-wink.gif[/IMG]
Old Feb 20, 2003
ak's Avatar
ak
Retired Mod
Quote
[hr]Originally posted by: andyman97
Holy **** bro, when did you become a mod? LOL, I missed that, you never told me [IMG]i/expressions/face-icon-small-wink.gif[/IMG][hr]
2/19 [IMG]i/expressions/face-icon-small-wink.gif[/IMG] oh yea, i forgot about the Scotch Brite pad.
Old Feb 20, 2003
01EMCVC's Avatar
Thanks for the tips, btu i am actually returning my interior back to stock color, so that's why i was wondering how to remove paint without harming the interior.......[IMG]i/expressions/beer_yum.gif[/IMG]
Old Feb 20, 2003
CrazyCakes's Avatar
CrazyCakes is an unknown quantity at this point
I bought this stuff called oops grafiti remover and a nylon brush. it was a pain in the *** but it did the trick and left no scratchs. good luck bro and if all else fails order new parts through honda, trim peices arn't that expensive
Old May 25, 2003
orion_squall's Avatar
hi,
when you whentioned "pasti-kote", what is plasti-kote?
is it a brand?
because I used "U-fix-it" vinyl paint from canadian tire and it sucked.
Old May 26, 2003
ASWZero's Avatar
ASWZero is an unknown quantity at this point
Check it out.
Plasti-koke .
Old May 26, 2003
dj pyrotechnics's Avatar
dj pyrotechnics is an unknown quantity at this point
lol... plati-koke
Old Jun 3, 2003
LAKAS187's Avatar
LAKAS187 is an unknown quantity at this point
Can you use goof off to remove paint from a trim piece??????
Old Jun 3, 2003
ak's Avatar
ak
Retired Mod
no.
SammySC
121
Apr 7, 2017 07:43 PM
UltraHDGames
Jun 8, 2016 05:16 PM
cferry7
Oct 18, 2015 06:32 PM
carid
Sep 28, 2015 10:13 AM
speedlever
Sep 24, 2015 07:18 PM
