Great Big Problem....VAFC...Help fast!!
Old Jan 9, 2003
Hwoody77's Avatar
Hwoody77 can only hope to improve
Ok, so here's the deal guys. I recently installed my V-AFC, I had the same check engine light like everyone else.
For about 2 weeks, I kept disconnecting the battery in order to have the Check Engine light go away because of the V-AFC.
But here's the problem, recently my car began to stutter, like I'll be driving, and the car will die at low RPMs, I tyr to restart it and the car dies. The car would also stutter when I let go of the gas.
Then my friend began pulling the O2 sensor on the intake, and it went away. So what do you think happened? How can I fix this? An 02 simulator? Maybe I reset the ECU too many times, and it's not used to all this air?
Old Jan 9, 2003
2k2civicRAY's Avatar
2k2civicRAY is an unknown quantity at this point
Maybe you accidentally pulled on some wire and it came loose from where ever it was connected. Check all your wires with a multimeter, this might be the problem and when your friend was pulling on the intake sensor wires, they made contact again.
Old Jan 9, 2003
bobbyd's Avatar
bobbyd is an unknown quantity at this point
maybe it is just a bad alternator or battery or something too?
Old Jan 10, 2003
Pinoyexposed's Avatar
Pinoyexposed is an unknown quantity at this point
Thats scary man[IMG]i/expressions/face-icon-small-disgusted.gif[/IMG] hope you could fix that problem[IMG]i/expressions/face-icon-small-sad.gif[/IMG]
Old Jan 10, 2003
HondaLuver's Avatar
Its a celebration bitches!
dam that is weird, the only problems that i have had are the light and not being able to rev over 4k sometimes... i know its connected right though.
i have concluded that the only time that the V-afc will work right and no engin light is when it is warm or hot outside... other than that it will not work right... such as the night or snow.
Old Jan 10, 2003
mrdan4548's Avatar
mrdan4548 is an unknown quantity at this point
mine did throw a check engine light at first but we had the pressure wires backwards and the vtm wire wasnt cut goin towards the car. Now my friend who installed it recorrected the problem and its almost 2 weeks already and still no light. Im guessing when you pulled the vtec wires out u mustve accidently disconnected something else. Do you have any other settings that you have changeD? Sometime tommorow im gonna post up my dyno sheet so everyone can see im not lying or bsing or nothing, oh and when your resetting the ecu just take out the 15amp fuse to the ecu its alot easier and faster. Trust me. so hth. [IMG]i/expressions/face-icon-small-smile.gif[/IMG]
Old Jan 10, 2003
Boosted's Avatar
Boosted is an unknown quantity at this point
You engine is stuttering because the Map sensor is sending incorrect data to the ECU. It has nothing to do with the wrong wires attached or cut or anything like that. Also, you will not be able to control the V-Tech portion of your car with the V-AFC, This is straight from Apex'i R&D. just disconnect the V-Tech part of the V-AFC and hook the wires back up like they were. If you set your AFC right you can make the Vtec shift a lot more noticeable anyways.
TKS
Boosted
Old Jan 10, 2003
CivicGirl482's Avatar
CivicGirl482 is an unknown quantity at this point
I had an V-AFC controller in my civic last week and I had the same exact problem with mine, the check engine would turn on, couldn't go past 4,000 rpm's and the car was shaking bad. I took it to our import shop in town, it was in the shop for 2 days and in the end, the controller had to go.
The guys called Apexi up and they sent them a fax saying that in 2002 the controller will not work. It will throw check engine lights depending if the car is cold or warmed up. They also said that it's because in 2002 the civics have 3 VTM wires, one when it's cold, one when it's hot and one when it's average temperature, the controler is looking for only 1 wire.
They tried conecting all wires, just one wire at a time and the check engine would still turn on depending to which VTM wire it was hooked up with. Apexi said that it works with 2001 and below, not 2002 and up yet, they're in the process of developing one.
Really made me upset, it worked nice when it did the few times and I didn't get a check engine, but not if lights keep comming on and it can't shift right.
Old Jan 10, 2003
Sweetpants's Avatar
Sweetpants is an unknown quantity at this point
great i can just imagine how much a vtec controller is gonna cost when it is only developed for 1 car.
Old Jan 10, 2003
CivicRicer02's Avatar
CivicRicer02 is an unknown quantity at this point
This is very true.........
Old Jan 10, 2003
kustum2k1LX's Avatar
kustum2k1LX is an unknown quantity at this point
Dont know if you guys have figured it out, but The VAFC CONTROLLER DOES NOT WORK, IT IS INCOMPATABLE WITH OUR ENGINE AND COMPUTER. YET THE AFC CONTROLLER WORKS. OR ATLEAST THATS WHAT I HEAR FROM OTHER POSTS ABOUT THE SAME PROBLEM.
Old Jan 10, 2003
Actuely the AFC controller doesn't work either with our cars. 2001 and up Civics are ULEV (Ultra Low Emisions Veihicles) and the O2 Sensor sends out a different signal to the computer than the controler can put out. Therefore the AFC controller will not work either...sucks. [IMG]i/expressions/face-icon-small-sad.gif[/IMG]
Old Jan 10, 2003
Wanger's Avatar
Wanger is an unknown quantity at this point
Quote
[hr]Originally posted by: CivicGirl482
Really made me upset, it worked nice when it did the few times and I didn't get a check engine, but not if lights keep comming on and it can't shift right.[hr]
are you sure you didn't mean 2000 or below? because i have a 2001 ex (the one apexi posted a diagram for) and i have the same cold engine light problem.
Old Jan 10, 2003
Wanger's Avatar
PEOPLE, everything works, it's just the engine light. once u warm up your car until the vti doesn't jump like crazy, then reset your ecu. after that it works, i had vtec turn on at 4200rpm and off at 3500. AFC works too, it's just the engine light keeping ya to 4000rpm or below, thats how honda keeps your car from blowing up until you get to a mechanic.
btw, OBDII error code for the engine light is 1259 which is the "vtec solenoid" error code and the manual says to check the vtm connections of the stock ecu to the stock vtm sensor (no vafc) so it's a vtm problem.
Old Jan 10, 2003
HondaGuru's Avatar
From: San Diego, California, USA, Northern Hemisphere, Earth, Sol System, Spiral arm of the Milkey Way
HondaGuru is an unknown quantity at this point
...yet one more VAFC post...
Old Jan 10, 2003
CapYoda's Avatar
Escaped Convict
btw o2 sensor has little to do with the VAFC...
there's no o2 sensor on the intake assembly, thats the MAS (mass airflow sensor)
o2 sensor are on exhaust manifolds or behind cat convertors.
seems like a conflict going on here. we got some saying all the features work and some saying the vtec controller feature doesn't work..
GolNat
Suspension DIY
May 12, 2022 06:49 AM
7thgensurvivor
38
Aug 29, 2015 11:50 AM
beveragemp
May 25, 2015 07:11 PM
bsmiley
Apr 27, 2015 01:27 PM
supercivic01
South
Nov 30, 2001 11:27 AM
