HELP QUICK!!! REMOTE START
Old Dec 28, 2002
XtremeJM's Avatar
OKay... I am having problems with my remote start... wanted to know if anyone had the same issue....
My directions state.... Wire purple wire to Engine Sensor Wire. So I am like WTF.... Well I had help
installing it from a friend of a friend... we got the whole alarm down easily... But he said the purple wire is
supposed to go to the tach sensor wire. So we did that.... Car starts....5 seconds later it turns off and gives
us the UNSUCCESSFUL START beeps. So I am like hmmm......
The manual says the purple wire goes to the sensor wire that reads negative or 3V-4V on some cars in the on position, but when in the start posisiton it reads 12V. Well the tach does not read those amounts....
Has anyone experienced this, I did a search... PLEASE HELP ASAP
AIM: Xtremejm
Old Dec 29, 2002
mrdan4548's Avatar
mrdan4548 is an unknown quantity at this point
What kind of alarm are u using?
Old Dec 29, 2002
Aaggie77's Avatar
Aaggie77 is an unknown quantity at this point
Is your doors open or closed? I thought that if you use a remote start that once you open the door to your car you have a couple of seconds to place your key in the ignition before the engine will auto cut-off.[IMG]i/expressions/face-icon-small-confused.gif[/IMG]
Old Dec 30, 2002
AlpineCivic's Avatar
Our cars have a transponder which means if the key is not physicaly in the ignition it will not allow your car to start or turn off when the remote start trys to turn it on.so you have to bypass it in order to get it working right. PM me if you want me to send you a diagram for it!!!
Old Dec 31, 2002
XtremeJM's Avatar
Ive got the transponder, just something else isnt right
Old Jan 1, 2003
mcflyo219's Avatar
mcflyo219 is an unknown quantity at this point
Hey did the wire diagram i sent u help any? Did u get the transponder with the wire hoop that goes around the key cylinder? If u did, u might have to adjust it until the car stays running.
Old Jan 1, 2003
XtremeJM's Avatar
I think it has something to do with the brake sensor, i tried doing the remote start while sitting in my car, and it still started, so maybe i was thinking the brake sensor is not hooked up right, but i checked the connections and the wire, everything is right... hmmmmm i am so f-ing confused
Old Jan 1, 2003
XtremeJM's Avatar
The pics on the wire diagram still didnt show up, i think they have some sort of protection on them so you cant link them.
Old Jan 1, 2003
mcflyo219's Avatar
U can't access the pics unless u have dealer code, sorry can't give that out. to make sure it's not the brake wire just diconnect the wire, start the car. Do u have a neutral safety switch on the alarm?
Old Jan 8, 2003
XtremeJM's Avatar
What is a nuetral safety switch? I disengaged the clutch sensor
Old Jan 10, 2003
mcflyo219's Avatar
Nuetral safety switch is on some alarm, I don't know if u have that or not. But it's just a ground switch that u turn the remote start option on or off. Just say u let let someone burrow ur car and u turn the remote start off so they won't accidentally start the car. That wire has to be grounded for the remote start to work.
Old Mar 24, 2003
NorrinRadd's Avatar
NorrinRadd is an unknown quantity at this point
Quick question xtremejm, what alarm do you have and how did you turn off the clutch sensor? I have a Python 880xp and would like to use remote start on my 5speed as well, thanks.
Civic2002lx
Oct 7, 2015 09:17 AM
MamaBear2015
May 3, 2015 02:17 PM
DaveyD
Mar 28, 2003 12:28 AM
black2k1vtec
Dec 6, 2001 09:49 PM
loquito
Nov 12, 2001 07:24 PM
