hyperblinkers
hyperblinkers
anyone got any pics of what the box looks like in stores, iseen like ones wher u have to drill or soemthing then iseen ones that you just unplug something and plug in another thing that lets it blink fast
I have the HyperBlinker Strobe V2 in my car and it blinks super fast. I'm thinking about trying out the Blinker 2X V1, which is supposed to be a little slower.
Hyper blinker home page
this site has a link to display the effect of the different blinkers.
If you are asking what the part looks like go to a parts store and look for a turn signal relay. its a small black box with a three plug prong. its direct replacement, like a fuse. don't but anything where you have to cut n' splice. its just not necessary
Just to add, you do not have to buy the hyperblinker relay. You can make your own by modifying the stock one. What the people did was solder a resistor into the stock relay. I think they used a 120 rate one or something like that. And the lower the number the faster the blinker.
www.hyperflasher.com is cheaper [IMG]i/expressions/face-icon-small-wink.gif[/IMG] than www.hyperblinker.com
I personally like stock
All Show No Go Sedan
The hyper blinker is just a small 1 1/2 inch relay u switch with the one under ur steering wheel on the driver's side. It was pretty easy to install, but I needed my friend to do it for me, cuz he has smaller hands. I got mine on ebay for $20. I know that u can make your own, but I'm not trying to mess with my car like that, I've heard of people messing up. Here's a picture of the stock one.
[IMG]/forums/themes/orbitz/paperclip.gif[/IMG] blinker.jpg (42 Kb)
lol he took a picture, thankz. to bad my car is stuck in like 100 ft of sno and i cant go out n buy it and i didnt get a chance to install the intake either def tommoro, ill let u all kno how it goes.. the unnoficial quarter mile speed is like 89 mph stock on my car i did it liek 5 times on a long road with my friend... dont have netimes though lol, it was ghetto i reset the odometer and floored it when it got to.4 my friend took the speed
Quote
[hr]Originally posted by: BaNgCiViC2k1
[hr]
I literally just finished switching from a 6x to a 2x blinker. IMO 6x and 4x are just too fast, especially 6x. you cant even tell you're signaling. with 2x, there is a noticeable difference, and it's the least ricest.
What i mean is, a normal l.e.d bulb from apc ( 7440 i think ) will make that work for about 7 dollars ea.! this might be the part # 50149b its just white but you can get red too!! Check it out!!! cheap ,easy!!!
DIY King
Just in case people don't know, there's a DIY for this: DIY: Hyperblinker
Retired - SoCal FI Mod
my hyperblinker setup is ghetto... i just cut the power wires on the signal light harness and switched them around... the back hyperblinks but the front stays lit and doesn't blink...
Hey guys,
Ummm... Instead of cutting apart delicate electronic components I would try cvconedge's suggestion about the low watt L.E.D change. Some how I can't see Honda honouring the warranty after they find the reversed wires or soldered resistors. The L.E.D bulbs do work and are a much cheaper alternative to paying $60.00 an hour shop labour at the dealership.
Give the L.E.D bulbs a try... they work in all the cars around here!
Later! [IMG]i/expressions/face-icon-small-smile.gif[/IMG]
i just installed my hyperblinkers and the little lug nut would come off!!! i ended up pulling so hard it broke but i managed to pull the fuse box out and everything i hope still works...o btw...the hyperblinkers are tyte i likey
The DIY hyperblinker you linked to is ONLY FOR COUPES.
Sedans have a different relay that the coupes.
Dont try the same method for the coupes on a sedan. It will blink super fast![IMG]i/expressions/laugh2.gif[/IMG]
This is the DIY I made for the sedans enjoy! DIY HYPERBLINKERS FOR SEDANS
FALKEN
24
Jan 31, 2007 03:23 AM
