crank pully help??
Old Oct 15, 2002
Black99Vtec's Avatar
first member with a d16 swap
Black99Vtec should not be trustedBlack99Vtec should not be trustedBlack99Vtec should not be trusted
crank pully help??
does anybody know how to get our crank pully off i keep breaking tools. i have a impact gun and that didint get it of either. is there a trick to it. i had like 600 foot lbs on it and it didnt budge
Old Oct 15, 2002
JDM1982's Avatar
JDM1982 is an unknown quantity at this point
Are You sure your going in reverse, if so, is the impact gun putting 600 lbs out in reverse?
Old Oct 15, 2002
lagger's Avatar
lagger is an unknown quantity at this point
There is a special tool that you can purchase from Snapon called a crank pulley holder. It costs $62, but let me tell you, it is worth it's weight in gold. I broke one breaker bar so far, but it was on it's way out anyways. I tried using an impact wrench, but also had no luck, once I put the pulley holder in there w/ the breaker bar, about 5 seconds later i was sliding it off =)
If you are in the MA area I can give you a hand if need be.
Old Oct 15, 2002
smpcivic's Avatar
smpcivic is an unknown quantity at this point
mine came off good with an impact gun after i let the compressor run for a while
Old Oct 16, 2002
2001civ's Avatar
2001civ is an unknown quantity at this point
i took mine off this weekend. It's not to bad, I put a screwdriver in the flywheel and had a buddy hits the breaks aswell and i just used a socket wrench and a cheater bar. It took some force but it came off without breaking anytools and it didn't hurt the flywheel.
Old Apr 9, 2003
cdmx's Avatar
ahh crap i cant get mine off either, im thinking about attempting what 2001civ did...........Or im ill use my clamps and then the impact wrench
Old Apr 9, 2003
cdmx's Avatar
Can someone help me with some ideas on how to get the crank bolt off?? I have two clamps on it and it still wont come off......I have no idea how to stick a screwdriver in the flywheel (i will consider trying it) but any ideas will be great ( i know about the crank holder and i dont have one)
Old Apr 10, 2003
bhaz413's Avatar
Support your local 81
From: In the land of milk and butter, Massachusetts, US
bhaz413 is an unknown quantity at this point
lagger has all the tools
nola000
Engine start problems
63
Feb 17, 2023 09:18 PM
68camerors
Sep 24, 2015 06:18 PM
Skunkone
Sep 24, 2015 04:38 PM
SolidHollow
15
Sep 13, 2015 11:18 AM
