Koni Squeaks?
Old Oct 2, 2002
Intruder's Avatar
Intruder is an unknown quantity at this point
Koni Squeaks?
Hey, I looked around but haven't found anything on this. I have had Koni's and H&R's for about 3 months now, and the rear continually squeak. I pulled the lower arm bold and lubed the lower mount bushings with never seize and various othger silicone greases, still they sqeak. Just seeing if anyone has had this problem, next weekend I am going to pull them off, soak the bushings overnight in marine grease, and drill a zerk grease fitting into the bushing (and rout out an annulus with a dremel). If they still sqeak after that maybe I'll put the factory rubber bushings in the konis. Thanks for any input.
Old Oct 2, 2002
nytejade's Avatar
nytejade is an unknown quantity at this point
It's probably not your shocks. It's either your springs or your breaks or something.
Old Oct 2, 2002
pdxbiker's Avatar
pdxbiker is an unknown quantity at this point
Do you have a camber kit, If yes that maybe the cause of your squeaks.
Old Oct 2, 2002
Intruder's Avatar
no camber kit, but I just realized it could be the spring sqeaking inside the plastic sleeve it sits inside at the perch (*anti-noise devices*), maybe I'll try and check that out this weekend.
Tedverseti
Sep 29, 2015 05:41 PM
beanhead
Sep 24, 2015 12:04 PM
czarlun
Sep 14, 2015 08:16 PM
cukaracha
Aug 29, 2015 05:27 PM
VTECnique
Mar 20, 2002 08:06 AM
