i got washer LEDs on 24/7, is it ok?!?
Old Sep 14, 2002
  #31
iluvbritney's Avatar
iluvbritney is an unknown quantity at this point
well the DIY was kinda weird so i just did it my way, it was much quick and easier too. it looks great and i have a switch for it too. [IMG]i/expressions/face-icon-small-smile.gif[/IMG] [IMG]i/expressions/laugh2.gif[/IMG]
Old Sep 14, 2002
  #32
WeSSoN's Avatar
WeSSoN is an unknown quantity at this point
Another waste of bytes by Like Weeee, you know what....your a loser dude.....y dont you just KEEP YOUR USELESS COMMENTS TO YO'SELF....[IMG]i/expressions/moon.gif[/IMG][IMG]i/expressions/moon.gif[/IMG]
Old Sep 14, 2002
  #33
i was keeping this thread up-to-date about the "topic", dont be all offensive cause your mom never had a chance milk u.
Old Sep 15, 2002
  #34
Oishi's Avatar
Oishi is an unknown quantity at this point
i can give you a few suggestions...i'm not sure if your led washer lights have two or three wires...i'll assume two wires
1) run the led wires to your parking light wires. for this, spend an extra couple of dollars by buying some components (you will need four in total) that connects two wires together without splicing any wires. you can research these and ask for samples so you won't have to pay anything but it will take about a few weeks...or just splice the wires carefully and connect it that way. (RECOMMENDED)
2) if you want the led on only when the car is on...run the led wires towards the firewall where a rubber grommet is covering a hole that leads towards the inside of the car...connect the negative (black wires...if it is color coded) towards chassis ground and the other (red wire) towards your +12V accessory wire...that is the wire that connects to the accessory plug...if you want a switch then connect the red wire to a switch first (assuming it is a spst switch...no light...regular switch)...then the other to the +12V accessory wire
3) if you have a lot of time...buy one of those solar detectors and connect it so it will come on automatically when it is dark...
4) connect it to the signal turn lights...
i used to have white ones as well but they turn a little bit bluish before then i changed them to the yellow leds...they look great (before i took them off) because the color is then similar to the turn signals and they are cheap and widely available unlike blue or white leds...
h4ldol
Apr 24, 2017 08:16 PM
frank_kleng
Sep 29, 2015 10:55 PM
MamaBear2015
Sep 24, 2015 11:34 AM
Klame9420
Sep 18, 2015 12:37 PM
