Burning Oil? re-fill?
Old Sep 9, 2002
7GRev's Avatar
7GRev is an unknown quantity at this point
Ive been driving my car pretty hard lately, and the oil level seems to be down... what kind of oil do i use to top it off... in the manual it says Honda oil only, but what is that? what kind do you guys use? thanks!
Old Sep 9, 2002
C2i0v0i1C's Avatar
SuperMODrizd
have u ever changed the oil in it, if so use the same stuff u put in last time
Old Sep 9, 2002
Boilermaker1's Avatar
Jap-Euro Fusion
5W-20, like it says in the manual. If it was conventional, put conv. back in. IF Synthetic, use that.
Old Sep 9, 2002
APS's Avatar
APS
APS is an unknown quantity at this point
Castol Synthetic...5w20 or 10-w30...is the way to go...
Old Sep 9, 2002
orso's Avatar
orso is an unknown quantity at this point
mobile1 5w 30
Old Sep 10, 2002
1955's Avatar
u should try to solve the reason why it uses oil and u said it seems to be down,,u have to be sure if it is,,, drivin hard has no effect on the engine consuming more oil..it cant be a leak cus its a honda..i am serious..
Old Sep 10, 2002
CoupeStylz's Avatar
Si(R) killer # 1
CoupeStylz is an unknown quantity at this point
Burning oil comes from worn engine internals, like piston rings. There is no way such a new car should have this problem.
Old Sep 13, 2002
WeSSoN's Avatar
WeSSoN is an unknown quantity at this point
Just to let you know...this is what I've head...so I dont know if its right...but....I've heard that when vtec engages it burns oil...not a hell of a lot but it does nonetheless....but yeah...that's what i heard fro a Honda mechanic...but...yeah...
Old Sep 13, 2002
1955's Avatar
wesson,that probably true,i know modern day engine tend to use oil a bit more but to a certain degree,.put a large piece of cardboard under the engine after it has been runnin to check for leak,if none,assume the particular engine 7grev has indeed use more oil,i believe half of a qt in 3,4 k miles is normal.
Old Sep 13, 2002
Collective's Avatar
Collective is an unknown quantity at this point
Maybe its that thin 5W20 ? It's got to burn faster than say, a 5W30... ? (just a thought) [IMG]i/expressions/face-icon-small-confused.gif[/IMG]
Old Sep 17, 2002
stackz's Avatar
stackz is an unknown quantity at this point
vtec doesn't use oil....just people that abuse the vtec to the point of ring breakdown causes vtec to use oil.......
this is a an old world technique of used car salepeople handed down for the long haul...."keep it secret, keep it safe".....
if you're car is burning light amounts of oil....puffs of blue here and there but not a steady stream like a locomotive...just drain the oil (don't replace the oil filter) and add 1 quart of automatic transmission fluid and fill the rest with 20weight oil....
the transmission fluid is nothing more than an extreme detergent inside the engine and will free up the quickly frozen rings....drive the car good an hard (not TOO hard) for either a week, daily or for about 500 miles then completely drain the fluid, change the oil (use cheap filter and oil...run another 100 miles or so to finish flushing out the transmission fluid...then change back to normal nice quality oil and filter and you should be golden unless cylinder wear was way too much or the rings were definitely toast.....this will tell you if you've got a serious problem about to happen to your car or not in a cheaper way than any mechanic can....
sure they can do a compression test on a dead cylinder with bad rings......but if you can free those rings for $35 dollars in your own time and not spend $500-1000 getting the engine rebuilt/replaced...why not.....
take this info for what it's worth....
-stackz
Old Sep 18, 2002
1955's Avatar
STACKZ,,THEY ONLY DO THAT IN A REHEARSAL FOR THE"BEVERLY HILLBILIIES" TV SHOW AND I THINK THEY USED THAT AS A REFERENCE FOR THE "3 STOOGES"AS WELL..OH WELL WHICH EVER COME FIRST.
Old Sep 18, 2002
stackz's Avatar
haha, shame on you making fun of my examples.....
-stackz
brags
46
Jan 7, 2016 09:39 PM
emich
Dec 11, 2015 12:20 PM
1khilari
Jul 9, 2015 08:12 PM
