help! overtightened bolts
Old Sep 5, 2002
LikeWEEEEEEEEEE's Avatar
LikeWEEEEEEEEEE is an unknown quantity at this point
i installed my kumosport brushings just now, which was going reasonable till my mind started to wander and i overtightened 1 or 2 of the bolts. will they spin loose when im driving on me or something? how secure are they?
Old Sep 5, 2002
silverdevil's Avatar
silverdevil is a glorious beacon of lightsilverdevil is a glorious beacon of lightsilverdevil is a glorious beacon of lightsilverdevil is a glorious beacon of lightsilverdevil is a glorious beacon of lightsilverdevil is a glorious beacon of light
How do you know you overtightened them? Were you using a torque wrench? Anyways, better tighter than looser. And no, they won't come loose because you overtightened.
Old Sep 5, 2002
VNlilMAN's Avatar
The Standard One
uh.. why not just loosen it a bit then?
Old Sep 5, 2002
IDQcivic's Avatar
IDQcivic should not be trusted
Maybe he tightened it so much that he stripped it, then it might spin.... If you're worried try putting some locktite on it
Old Sep 6, 2002
DaCurryman's Avatar
DaCurryman is an unknown quantity at this point
What's "locktite" ?
Quote
[hr]Originally posted by: IDQcivic
Maybe he tightened it so much that he stripped it, then it might spin.... If you're worried try putting some locktite on it[hr]
Old Sep 6, 2002
2Hottie's Avatar
2Hottie is an unknown quantity at this point
Quote
[hr]Originally posted by: DaCurryman
What's "locktite" ?
Quote
[hr]
It is a threadlock compound...basically gives nuts and bolts a secure connection for nuts and bolts that are located in high vibration areas such as exhaust bolts, lugs nuts even....
2Hottie
Old Sep 6, 2002
Grey's Avatar
DIY King
Yeah, how do you know that you overtightened it? Did you strip the thread and now the bolt spins around? If so, then you should take out the bolt. Then drill out the hole and make it bigger. Then re-thread it. Then screw a bolt in that's similiar, but is a larger diameter and with the right threading. Assuming that there's enough space for a bigger bolt with those KumoSport bushings.
If not, then forget that. You either stripped the bolt's threads or the threads in the hole. You'll have to check which one. If it's the bolt, then you'll need another one. Then just screw it in and you should be okay. If it's the hole, then you'll need to go under the car and look for the bolt sticking out and put a nut on from underneath. Those holes are under the car somewhere. If it's both, then you'll need a new bolt and a nut. Pretty self-explanatory. Just do it right and you should be okay.
Also, if it's just one bolt, then it won't make a big difference, but the other bolts will be strained more when you shift and they might come loose or they might even break. It depends on how hard you shift. Good luck.
Tedverseti
Sep 29, 2015 05:41 PM
rovafa2002
Sep 28, 2015 06:57 PM
2002ExCivic
22
Sep 28, 2015 08:29 AM
pilebuck13
Sep 21, 2015 10:45 PM
amrhamed
Sep 21, 2015 02:56 PM
