how to paint headlights
Old Aug 26, 2002
chucky's Avatar
chucky is an unknown quantity at this point
what's the best way to paint the inside of the head light to give it that "black housing" effect
Old Aug 26, 2002
4drcivic2k1's Avatar
Turbos, Engines, Chassis and Suspension Tech
4drcivic2k1 is an unknown quantity at this point
spray paint
Old Aug 26, 2002
Clownswlleatu's Avatar
Clownswlleatu is an unknown quantity at this point
I used the carbon fiber look vinyl. Looks good and is more original.
My Ride
Old Aug 26, 2002
TuffVietta's Avatar
TuffVietta should not be trusted
that carbon fiber insert looks tite. where did u get it and how much as it?
Old Aug 27, 2002
Purple2001Civic's Avatar
Purple2001Civic is an unknown quantity at this point
i used spray paint on mine and they come out real good . man those head lights are tight like the way they look
Old Aug 27, 2002
WhiteRiceBoi's Avatar
WhiteRiceBoi is an unknown quantity at this point
Quote
[hr]Originally posted by: Clownswlleatu
My Ride[hr]
wow it looks like you took some time doing it looks very neat, GJ man.
Old Aug 27, 2002
oblivious9's Avatar
oblivious9 is an unknown quantity at this point
or you could buy black housing headlights from tornactive.
here's what they look like on my car.
Old Aug 28, 2002
V4sh's Avatar
V4sh is an unknown quantity at this point
I have a black 2k2 civic. How many layers of spray paint should I use in the rear lights to smoke them? Also, how do I take out the rear headlights? I want to do this myself. Also, I have problems taking out the front headlights. I want to clear the ends but there is a third bolt which is inaccesible to me. My friends say that I have to remove the whole front bumper to take out the headlights. Is there any way that i can take out the headlights without removing the bumper?
Old Aug 28, 2002
chucky's Avatar
Is there an easier way to seperate the lens from the headlight than just prying it?
[IMG]i/expressions/face-icon-small-confused.gif[/IMG]
Old Aug 29, 2002
PeArlHoNdA's Avatar
PeArlHoNdA is an unknown quantity at this point
ok ill answer last 2 questions...1st one is no, front bumper has to come off to get headlight out. 2nd one...put ur headlight in the oven on 200 degrees for bout 8 mins. It will loosen the sealant and u can pry it right apart...just be careful. Its easy so dont freak out cause i told u to cook ur lights...it works!
Im a SUPER member....plus ive done it like 10 times workin on my friends rides [IMG]i/expressions/face-icon-small-smile.gif[/IMG]
PeArLhOnDa
Old Aug 29, 2002
V4sh's Avatar
How much spray paint do I use in the backheadlights so that i still may be able to see the white reverse light and the red lights. I want to smoke my rear lights but I want to be able to see the white reverse lights and the parking lights clearly too. How do I take out the rear headlights?
Old Sep 2, 2002
PeArlHoNdA's Avatar
to take the rear lights out u unscrew the screw thats holding the carpet in, pull back carpet and u will see the bolts that hold the lights, unplug the bulbs, remove the bolts and the tails pop right out...easy bro...easy
PeArLhOnDa
Old Sep 2, 2002
dragoon's Avatar
Quote
[hr]Originally posted by: V4sh
How much spray paint do I use in the backheadlights so that i still may be able to see the white reverse light and the red lights. I want to smoke my rear lights but I want to be able to see the white reverse lights and the parking lights clearly too. How do I take out the rear headlights?[hr]
rear headlights - do you mean the tail lights? well just peel back the carpeting in the trunk and you'll be able to get at everything. as for the headlights, just mask off the parts inside the chrome. check my members' rides page.
Old Sep 3, 2002
BCSports02's Avatar
BCSports02 is an unknown quantity at this point
Question...so let me get this straight b/c I was told differently...
You can clear out your head lights by sticking them in the oven for several minutes??
I thought that you had to buy a whole new set of clear headlights?
Brandon
Black 02 Civic Ex
DC Sports Header
AEM CAI
EVO Catback
Old Sep 3, 2002
oblivious9's Avatar
Quote
[hr]Originally posted by: BCSports02
I thought that you had to buy a whole new set of clear headlights?[hr]
Check the DIY & Search the forum. There are a million + threads on clearing headlights.
Anyway, I chose not to because they're stock so I don't want to ruin them & I plan on putting them on if/when I sell my car. Oh, and if you get a ticket for clear headlights, which are illegal...a stock replacement is a lot more expensive than buying aftermarket headlamps.
Old Sep 3, 2002
BCSports02's Avatar
I'm not sure which state you are from, but in Florida clear headlights are completely legal...clear taillights are illegal
BC
Old Sep 3, 2002
BCSports02's Avatar
By the way...thankyou for the link to DIY...I didn't know about that
BC
Old Sep 3, 2002
Mex's Avatar
Mex
Mex is a jewel in the roughMex is a jewel in the roughMex is a jewel in the rough
I understand you can take the reflector out of the housing too, so perhaps you could remove the reflector, spraypaint the reverse side with amber paint, and put it back. BINGO, legal semi-clear headlights would this work, anyone?
Old Sep 3, 2002
Rider's Avatar
Rider is an unknown quantity at this point
hmmmm I'M not sure I understant what you want to say....
Quote
[hr]I understand you can take the reflector out of the housing too, so perhaps you could remove the reflector, spraypaint the reverse side with amber paint, and put it back. BINGO, legal semi-clear headlights would this work, anyone? [hr]
Adding paint on the reverse side of the reflector will just stop the light from coming across the reflector....do I understant what you said correctly?? =)
Bye bye!
Eric
Old Sep 4, 2002
ohmysac's Avatar
ohmysac is an unknown quantity at this point
i was looking into this very thing...i was trying to find some transparent amber paint and i found some on autodynamic.com...its like a transparent amber spray that dries to a removable film...i ordered some but they were out of stock
Old Sep 15, 2002
iNteGraz92's Avatar
iNteGraz92 is an unknown quantity at this point
Quote
[hr]Originally posted by: chucky
what's the best way to paint the inside of the head light to give it that "black housing" effect[hr]
paint the housing black, duh
[IMG]i/expressions/face-icon-small-tongue.gif[/IMG]
SammySC
121
Apr 7, 2017 07:43 PM
UltraHDGames
Jun 8, 2016 05:16 PM
carid
Sep 28, 2015 10:13 AM
Sep 27, 2015 11:33 AM
speedlever
Sep 24, 2015 07:18 PM
