spare tire under...again....
Old Jun 28, 2002
WhiteRabbit's Avatar
spare under tire...again....
you guys do too much work (gets more publicity if its its own topic, thats why its here)
drill a hole the size of the stock bolt, if you have stock suspension, doesnt matter where, mine is in the center.
go buy a lock nut and a 1 inch washer, and just thread it back through. simple. took me 10 minutes to do, and driving over speedbumps has had no effect on it whatsoever. works great on a civic with stock springs.
Old Jun 28, 2002
StraightEdgeCivic's Avatar
StraightEdgeCivic is an unknown quantity at this point
hmmm...sounds good to me
Old Jun 28, 2002
MagicRacing18's Avatar
MagicRacing18 will become famous soon enoughMagicRacing18 will become famous soon enough
What did you use for the bolt part? some threaded rod?? if so, how long? and if not what did you use? Also, how did you conncect the tire to it on the underside of the car. Sorry for all the questions, I just want to be sure before i do anyhthing. Thanks
~nick~
Old Jun 28, 2002
thats the simplicity! its teh original bolt! just take it to the hardware store and match it to a bolt and washer, then drill hole. your done.
Old Jun 29, 2002
BigHippo22's Avatar
BigHippo22 is an unknown quantity at this point
I was wondering if that would work when I was reading all the DIYs...looks much simpler...let us know if it falls off!~!!!
Old Jun 29, 2002
i was thinking about that, actually. i think its rock solid, but if anyone has done this DIY and used another bolt, can you send me the stock one? I have access to a tensile tester, and might be able to persuade my professors into letting me run a tensile test of the stock bolt and the nut I bought. I would be able to get a fail stress, and let you all know how much force it took to break it....
but its a destructive test, so whoever loans me teh bolt can kiss it goodbye.....
Old Jun 30, 2002
Decamo's Avatar
Decamo has a little shameless behaviour in the past
I don't think thats gonna be able to handle the spare tire. That bolt in the pic could come loose. Did you put thread lock on it or something? At least put a second bolt to prevent the first from comming undone.
Old Jun 30, 2002
DxMaN's Avatar
DxMaN is an unknown quantity at this point
Quote
[hr]Originally posted by: Decamo
I don't think thats gonna be able to handle the spare tire. That bolt in the pic could come loose. Did you put thread lock on it or something? At least put a second bolt to prevent the first from comming undone.[hr]
I was thinking the same thing. Either a lock washer or an extra nut would work okay.
I think this method would work just fine, I was thinking of doing it to my ride. Only problem being if something is high enough to catch that tire. You'll seriously bend up your trunk floor and lose the tire. Also watch for rust around that freshly drilled hole.
Old Jun 30, 2002
its a lock nut, its not gonna come loose
my only worry is ground clearance, which ive driven around the parking lot for awhile at various speeds to test when i first did it.
it passes teh speedbump test, well see if it can hold for everything else.
and I will repeat, if anyone has a spare stock threaded rod, I will tensile test it with teh nut to see where failure occurs, and we will know for sure whether this is or is not enough to hold up teh spare!
GotSiR
Jun 23, 2016 04:06 PM
Strycker
Aug 18, 2015 02:25 PM
alaga
25
Aug 13, 2015 04:42 PM
EngiNERD
Aug 12, 2015 09:20 AM
mistermenphis22
Jul 13, 2015 04:43 PM
